I recently purchased a Pioneer A06 and tried to use Roxio 5 CD-Creator Platinum updated w/ the latest drivers (5.3.5.10) to burn a data DVD. Roxio complained that it couldn't find a valid DVD writer. (Nero found it just fine). I had a similar problem with a Plextor DVD/CD-writer combo but the update cured it.
Has anyone had a similar problem, and if so, is there a fix?
Thanks.
Nevermind!
There were 2 updates on the Roxio site. Just downloaded the other one and it works fine. It never fails. Look before you post. -
Watch out because the ROXIO 5 xxxx product had a bug that If you try topburn a DVD with less than 4 gig of files it cannnot finalize the disc!
It'll still work on a computer..but no set top will play a un finished disc (not closed )
OVER 4 gigs to burn..and it burns as well as NERO usually
Can Roxio USB capture be used without Roxio's software?
By miamicanes in forum Capturing and VCRReplies: 4Last Post: 18th Oct 2012, 17:30 -
recognizing MP4 vs MKV
By Leach in forum Newbie / General discussionsReplies: 9Last Post: 9th Feb 2011, 08:37 -
W7 not recognizing camcorder.
By stanl in forum Capturing and VCRReplies: 1Last Post: 12th Dec 2010, 21:08 -
All Drives Not Recognizing Discs
By Celcius in forum DVD & Blu-ray WritersReplies: 7Last Post: 31st Jul 2008, 16:33 -
pc not recognizing mini dv camcorder
By jbitakis in forum Capturing and VCRReplies: 2Last Post: 13th Sep 2007, 14:59
