Hi,
I use NeoDVD to create DVD's, in the options menu under "Audio", it has 3 options: LPCM, Dolby Digital, MPEG.
I have to use MPEG for the sound to work on my standalone DVD player. If I use LPCM, no sound comes out. The "Dolby Digital" options is shaded out so I cannot select it... why??
How do I get the best sound?? I author using Showbiz then I create the MPEG2 file for DVD, the sound is usually "tinny" and the mp3's that I put in are much louder than the dialogue in the footage, so I constantly increasing and decreasing the volume on my TV.
Aplogies in advance for my ignorance.
It's not a Black and White world, to be alive the colours must swirl.
And I believe that maybe today, we would all get to appreciate.... The Beauty of Gray.
- Ed Kowalcyk (LIVE) - -
What's most likely happening is that you're feeding mp3's in as the audio source, and they're being re-encoded to mp2 (which I believe is the only MPEG format supported for audio in (S)VCD/DVD). This often seems to cause problems.
I would recommend that you convert (decompress) the mp3 audio into 16-bit PCM (wav), and normalise it, before you feed it in to Showbiz (if this is possible - I don't know this software).
There are a large number of audio tools you can use for this.
e.g. SoundForge, CoolEdit, GoldWave, Audacity (from left ot right -expensive to free)
Can you set the bitrate for your MPEG audio within ShowBiz? mp2 doesn't tend to sound to great below about 192kbps. VCD has 224kbps as standard.
Converting the audio to wav and normalising it before feeding it into ShowBiz should improve the quality in the output, and solve your problem with uneven audio.
cheers,
mcdruid. -
Thanks very much, will try to do this.
Obviously "normalising" is performed within this software also????It's not a Black and White world, to be alive the colours must swirl.
Yes it is - normalise basically means to increase the volume to the loudest it can be without any clipping.
In SoundForge it's under Process->Normalize
In GoldWave it's under Effects->Volume->Maximise
and in Audacity I think it's under Effects->Amplify
For the simpler form of normalisation (of the three above, I think only SoundForge can do it any different), set the maximum to 98% or something like that.
cheers,
mcdruid.
Can someone explain clipping to me, and how to repair audio files?
By snafubaby in forum AudioReplies: 14Last Post: 28th Apr 2011, 15:15 -
Newbie codec question
By fotoruss in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 21:47 -
Newbie with a question on using Avidemux
By The Monarch in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 22:25 -
Newbie Divx question
By Contact in forum Newbie / General discussionsReplies: 13Last Post: 13th Apr 2009, 10:57 -
Newbie question about the audio sounds of my PC
By jeanpave in forum AudioReplies: 5Last Post: 12th Sep 2007, 00:32
