Ok, I have use inline autocomplet unchecked. But my IE bar and my emule search bar still contain my previous entries...how can I turn this off?
Boy do I love my avatar!
Go to start - settings - taskbar and start menu - select start menu - customize - CLEAR. That's in Xp other ones are basically the same. Then internet options - content - autocomplete - uncheck web addresses. You could also delete your cookies and temp internet files...
OR STOP LOOKING AT PORN!!!!!! -
Man, I sure hope that's your pic 808smokey....hotttttieee :P
I'm just joking. But she is hot. -
You can go to Tools->Internet Options->Clear History and set "Days to keep pages in History" to 0. Or just hit "Clear History" when you are done... "Surfing."
Or download one of the billions of programs that clears the porno, err history, from your pc.
see, i can clear my IE stuff and my windows stuff but the emule search bar is what's really killing me....Why does it save previous searches? I looked in the prefs and cant find anything about search bar history in there!!!
Boy do I love my avatar! -
Alright tsantsa you owe me a dollar. This was a little tricky but I got it..
Here's how:
1. Double click my computer
2. open C:
3. Programs
4. Emule
5. config folder
6. open the folder called "AC_SearchSTrings" with notepad
7. you should see all the porn stuff you search for :P
8. delete the XXX stuff or delete it all.
9. Use "save as" and over write the file.
10 fastest way... delete the entire file and eMule will make a new one
Happy XXX downloading
You might have to restart emule if you have it already running.
How to turn OFF subtitles in MPC
By pbuscher in forum SubtitleReplies: 5Last Post: 2nd Feb 2013, 23:51 -
Turn off Looping
By pepegot1 in forum Authoring (Blu-ray)Replies: 2Last Post: 30th Nov 2011, 18:02 -
Turn of visualization
By musomn in forum Video Streaming DownloadingReplies: 5Last Post: 23rd Oct 2009, 12:32 -
Turn .mpg into DVD?
By jnojr in forum Authoring (DVD)Replies: 6Last Post: 15th Dec 2007, 23:17 -
Help: Computer wont turn on!
By NateDizzle in forum ComputerReplies: 12Last Post: 20th Nov 2007, 13:10
