I have a 55Gb avi file. What program can turn this into a 700-800Mb
file?
Virtualdub.
open the file, go to Video->Full Processing Mode, then go to Video->Compression and select a more compressed codec, such as Divx.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
there should be codec configuration or quality settings - lower the bitrate or the quality.
if you want this on an SVCD, you need to convert to Mpeg, so you should use an application like TMPGenc to encode it (from your original avi file, not the divx re-encode).- housepig
Housepig Records
out now:
I believe DVD2SVCD can take an avi as input.
Because this guide tells me so ....
https://www.videohelp.com/forum/userguides/111846.phpI mean it in the nicest way.
need a free program to Compress MP4 files
By angryassdrummer in forum Video Streaming DownloadingReplies: 16Last Post: 2nd Jul 2012, 06:51 -
What program can compress videos to 700mb?
By Jmart285 in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jun 2010, 13:22 -
How to compress DV avi
By marti252 in forum Video ConversionReplies: 12Last Post: 7th Dec 2009, 03:12 -
Help with subtitles, compress avi
By hello123 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2007, 10:41 -
whats a good program to use to convert/compress to h264
By cowboysroy31 in forum Video ConversionReplies: 1Last Post: 20th Jun 2007, 19:28
