Does anyone know what software can increase the audio within a .mpg?
Or that can clip and change volume of .mp2 files?
The nearest software that I can find to do this is MP3trim
but it has file size limitaions!
Any help would be appriciated.
Thx Daz
You cannot do any form of audio editing on a MP2 audio file without re-encoding.
Thus, it may be worthwhile to simply decode the MP2 to WAV -- do all the necessary editing, and then re-encode it to MP2.
Regards.
_________________
Michael Tam
<font size=-1>[ This Message was edited by: vitualis on 2001-10-08 17:05:11 ]</font> -
GO TO CNET.COM AND GET BLAZE MEDIA PRO.YOU CAN CUT,CONVERT JUST ABOUT ANY AUDIO FORMAT.
Vitualis, I'm sorry to inform you but MP3trim can edit a MP2 audio file because I've done it, but it is limited to maximum 7 minutes!
But thanks for the input.
Thanks ripper I'll check it out
<font size=-1>[ This Message was edited by: JazzyDaz on 2001-10-09 11:42:40 ]</font> -
Never edited a mp2.
Cooledit is what I use. I know it has the volume increase feature. -
you can load the mpeg into http://www.goldwave.com but you will need to save it out as a wave
"Edit" as in changing the volume or doing anything to the actual audio stream. You can't do any of that without re-encoding the MPEG.
Obviously you can cut an mpeg...
Regards.
Michael Tam
w: Morsels of Evidence
Best way/tools to sync audio to movement of lips?
By J-E-T-S in forum AudioReplies: 18Last Post: 8th Mar 2012, 17:06 -
MPEG editing tools for the Mac
By HitTheRoad in forum MacReplies: 9Last Post: 7th Nov 2011, 16:43 -
What are the best free audio editing tools with VST support?
By babypotato in forum AudioReplies: 7Last Post: 18th Jul 2011, 00:00 -
what consumer/prosumer NLEs have good audio tools, and like mpeg-2+avchd
By mcbmcb0 in forum EditingReplies: 4Last Post: 3rd Dec 2010, 14:18 -
Ideal audio software tools ?
By tecbox in forum AudioReplies: 3Last Post: 22nd Feb 2009, 16:57
