Hi,
If I have one large recorded mpeg2 containing multiple parts that I want to cut away and merge the remaining parts into a new mpeg2 file, without having to recompress or anything AND keeping audio+video sync, what tool should I use... (see example below)
This would be ideal for editing out commercials etc.Code:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx source MPEG2 <-cut-><---keep---><-cut-><---keep---><-cut-> xxxxxxxxxx xxxxxxxxxx Result: xxxxxxxxxxxxxxxxxxxx
Any tool for this? The ones I've tried can only handle 1 <keep> part...
Results 1 to 25 of 25
antzen - absence of proof isn't proof of absence
www.industrial.se -
vitec dvd tool box can do this easly .. m2 edit pro should be able to also ..
Are those doing this WITHOUT having to recomress the mpeg? I know that eg. Premiere and Vegas has to recompress...
www.industrial.se -
TMPGENc Plus has a merge and cut tool in the MPEG tools section of the program.
How close do you need to get to a frame ?
"insisting on presence with no proof is insane" -
Womble MPEG-VCR (MPEG2 edition)
@andkiich:
I've tried TMPGEnc and it's terrible in keeping A/V sync.
Originally Posted by FOO
What I'm looking for is a freeware tool for this -small- task... but if I can't find it, I'll try to code a tool myself... however, this will consume alot of time (don't know that much about mpeg2 encoding/decoding at a programming level as it is...)antzen - absence of proof isn't proof of absence
www.industrial.se -
You are either a genius or completely crazy. If it was easy there would
be one already. I've been looking for 2 years -
as i said above "vitec dvd tool box can do this easly" it does not re-render and it can cut on a p or a b or a i frame (re-renders 1 gop around cut) , it also can cut edit ac3 files and a few other things ..
.. nah, not a genious, but rather well versed in programming.. I'm actually studying the mpeg2 specs for this task... and I think I'll produce something like:
Originally Posted by BJ_M
Why would I need a tool for this when there is such a tool like "dvd tool box"? - Well, to begin with... it's fun to code... but more important, it will be a small and fast tool that only do this.. (mpeg2 edit that is)... Let's see if I can produce something useful before I tire of the huge "information mountain" to climb before I know -what- to code...
I'll take a quick look at dvd tool box again, and see if it does what I want, if so.. then I may skip the whole coding business..antzen - absence of proof isn't proof of absence
www.industrial.se -
dvd tool box auto link points to the wrong thing (2 products with same name)
the auto link points to the wrong product
http://www.vitecmm.com/public/home/products/software.html?sess=1066770670
is the correct link -- totally different thing .. sorry about that"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by BJ_Mantzen - absence of proof isn't proof of absence
www.industrial.se -
Originally Posted by antzen
but thanks anyway...antzen - absence of proof isn't proof of absence
www.industrial.se -
Originally Posted by antzenICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Originally Posted by SLK001
Hmm, let me see, x-mas is in about 1.5 month.. that is plausible I think (I hope)... haven't really made any estimations for myself yet, but it would make a nice x-mas present, wouldn't it?
www.industrial.se -
I feel much (A) better now and (B) much worse now.
(A) The correct link to DVD toolbox makes much more sense.
(B) The editor is $250 -
2)If you are that worried about the email part, just set up a yahoo email adress, I mean who doesnt have junk email adresses just for doing stuff like that?
3) If memory serves me right, they have a public FTP server, so you can bypass the email registration.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
well the bad news is the price ...
the good news is that it is a lot cheaper than m2 edit pro ($1500)
i'm sure a lot of people would be interisted in a freeware version .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I have looked for quite some time also, and have found nothing 'free'. However, I have have found a tool that cost me only about $15 including shipping from ebay. VideoStudio v6 SE DVD does the the best job of of editing commercials of any application I have tried. VS 7 is great too, but cannot find it as inexpensive.
Check it out. Good tool and no endless hours of programming and debugging. -
BJ ?
Have you ever had a mixed 24/30 NTSC MPEG2 to play with ?
I'd like to know if that editor can remove middle sections without
causing audio sync problems. -
Hi there,
I use tmpegdvdauthor wchich has EXCELLENT cut Function, I think even exactly on a frame.
I also use ULEAD Moviefactory2 "Extract video" if it has not to be so exact.
With both programs I end up in VOB ready for burning, sometimes I reimport the vobs.
Both programs do no reconvert or touch the material, they "simply leave it out"
HTH
Tomgreetings
tom -
nope - havnt tried that"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
ill try it today
Tool for producing a "teletype" effect ?
By Bansaw in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2011, 23:01 -
keepvid.com and their new "high quality" download tool
By snafubaby in forum Video Streaming DownloadingReplies: 24Last Post: 8th Dec 2010, 20:19 -
Ask for Tip of a tool just like "Blu-ray to DVD II Pro"
By jjulio1 in forum Blu-ray RippingReplies: 0Last Post: 5th Aug 2010, 08:17 -
Tools suggestion: adding "see also:" to the searched tool ?
By vhelp in forum FeedbackReplies: 0Last Post: 22nd Feb 2009, 11:03 -
"Batch" editing/saving audio tool??
By clearvideo in forum AudioReplies: 16Last Post: 6th Apr 2008, 21:08
