I have a dvd that is in PAL . I'd like to convert it to Ntsc but without capturing him . Does dvddecrypter or any other software do this.
You can convert PAL to NTSC but this requires that you re-encode the video (and depending on the method used also the audio).Originally Posted by fabiohcruz
With a DVD source it is actually pretty simple.
Here are two links that give you all the information you will need:
1.) http://www.geocities.com/xesdeeni2001/StandardsConversion/
2.) https://www.videohelp.com/forum/viewtopic.php?t=160433
The first link is to Xesdeeni's website which has a lot of very usefull info on doing PAL to NTSC as well as NTSC to PAL.
The second link is a thread on this website where several people, including myself and Xesdeeni, discuss the gritty details in more depth.
Good Luck
No problemOriginally Posted by fabiohcruz
Should you have any questions feel free to ask here in this THREAD as that other THREAD is already long enough as it is hehehe
I have a question for ya FulciLives.
I hope you can answer (even if it sound ludacryst [spelling])
You can visit my thread over here:
* Converting 29.97 fps to 23.976 + pulldown to 29.970 !!
Thanks,
-vhelp 2026
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
