Hello
I just got done with converting a large divx avi to MPEG2 with TMPGEnc and it worked fine, and after I burned it on a disc and it plays back fine too.
I tried to convert another divx to MPEG2 again, but this time, even though the file is 4 MB smaller then the last avi, it says I would be 131 % capacity for my DVD.
Why the huge difference? The movie that it says would be too big is even 40 minutes shorter? I dont get it. Is there something I have to do to it?
Your second file likely has MP3 audio encoded using a variable bitrate (VBR). If you open the file with Virtualdub you will see a pop-up VBR warning. Goldwave can extract the audio to a wav file and you can use the wav as the audio source for TMPGEnc. Just load the avi into Goldwave then save.
BTW, the size of the avi does not affect the size of the mpeg, only the time and the bitrate."Art is making something out of nothing and selling it." - Frank Zappa -
Thanks. I'll try that. I did get that VBR error in virtualdub, but I didnt know what it meant.
is there any free application that can do what goldwave does other than virtualdub?
DVD (MPEG2) or DivX
By MI6 in forum Video ConversionReplies: 1Last Post: 20th Sep 2010, 14:51 -
vob/mpeg2 to Divx close to Dr Divx?
By Tiribulus in forum Video ConversionReplies: 8Last Post: 5th Dec 2009, 12:52 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 09:45 -
DivX and MPEG2 capture devices
By Arcturus in forum Capturing and VCRReplies: 18Last Post: 25th Aug 2007, 00:49
