I have found TMPGEnc the best encoder at low bit rates. It is far superior to anything else I have tried.
When I try to do 2 pass encoding the program stops after the first pass. Any help on this?
As I experiment with settings I just found something unusual but it is too late to fully explore. Normally the program closes when it is through encoding.
I changed the GOP settings so that frames are unlimited, I=1, P=10, B=3 and the program stayed open when it was done encoding. Tomorrow I will change the P frames downward until the threshold is reached when the program closes down when encoding is done. This may allow 2 pass encoding.
Until tomorrow.
AVCHD - Converting video pass 1: Errorcode: 0x0401,Error occured
By time2innov8 in forum Authoring (Blu-ray)Replies: 10Last Post: 19th Jan 2014, 14:20 -
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 15:59 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 06:59 -
Two Pass encoding error
By iSherbiny in forum EditingReplies: 0Last Post: 10th Jan 2010, 06:14 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16
