    Jul 2002
    Toronto Canada
    how do i convert a mpeg2 that has ac3 audio with virtualdub
  2. Banned
    Apr 2001
    Calgary, Canada
    You don't. VirtualDub doesn't support MPEG2 or AC3.
    If you want to try another program, try checking the tools area on this site, or *gasp* the guides section.
    Jul 2002
    Toronto Canada
    i did try looking but couldnt find out how and what do u mean gasp?
    Dec 2002
    You didn't say what you wanted to do. Are you converting to SVCD, DVD, DivX, RM, WMV, Cell Phone? It makes a difference if you need 3 tools or 5 to do it.
    Look for the VDUB mod series. one supports AC3 and the Other supports MPEG2. AC3 is covered quite well depending on what you want for a final product.
    Generally speaking what you asked for doesn't exist, that is an MPEG2 with AC3 sound, since it something that would only play on a PC. Did you mean a DVD?
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
