  1. I've ripped one DVD-5 using DVD Decrypter and burned it using Easy CD Creator v 5.3.5......Mine stand alone player hangs when i try to navigate across the original menus.
    The strange thing is I can watch the film - recorded DVD-R - in my computer using PowerDVD but, when I try to use WinDVD Platinun, the film hangs as in my stand alone player....Otherwise, WinDVD plays the ripped files in my hard drive without any errors!
    I've made the AUDIO_TS directory - empty one - before burning the DVD and tested the media with DVD Info...No erros.
    Can any one help me!
    Sorry about my terrible english, i'm Brazilian.
    Media - Ritek G04;
    Nec 1300A;
  2. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    If its a DVD-5 DVD then try ripping and burning with DVD Decrypter.
  3. First shoot your Ez CD Creator CD with a shotgun.
    Second use Nero to burn with. Nero is the best for burning DVD's.
    I still dont know what Ez CD Creator is good for, i use to have more problems and more coasters with Ez CD Creator, until i switched to Nero.
    Like Sifaga said, if it's DVD-5 then use DVD Decrypter to rip the entire disk to your hard drive and then burn it.
  4. Thanks!
    Yesterday, I burned again using DVD Decrypter and the copy is ok!! I think the problem is the CD creator...
    IŽll install Nero.....
  5. be sure to install one of the later version of nero or nero express. The earlier 5.5 versions messed up a lot of dvdrs. I actually use nero express as it simplifies it even more. Open nero, click on dvd-video, add the files and burn.
