HEY! I'm converting some old video I took a long time ago that I recorded onto the computer using JPEG compression .avi format. When I convert I get no picture (just black), audio is fine. Please help! Thanks!
Results 1 to 10 of 10
what are you playing the file on?
If PC then mediaplayer can't play mpg2 files... use a dvd player software package. -
When it's converting there is no picture, when in my dvd player no pic and when I use my computer DVD software, no pic.
If you try opening in media player do you get a picture.
If not then you no longer have the mjpeg codec loaded.
CHeck this first. -
Yeeah i would have to say no mJPEG codec. why do you use that anyway, its a load of rubbish. you cant get same quality with 1000x smaller file size with mpeg-4
goto http://www.mpegx.com for a range of mJPEG codecs, be careful though, 1 of them is an absolute shocker. -
I'M SURE THAT YOUR PROBLEM IS ABOUT VFAPI CONIGURATION ON TMPGenc SOFTWARE.
Set your avi codec to the highest priority and try to encode it again. While you don't get see picture at same time of encoding the resulted will be only sound.
Good luck.
Bye -
Thanks, I don't use jpeg codec anymore, I use divx
. It was the first thing I did on my computer and i didn't know any better.
Using TMPEGEnc, I can watch the vid with and viewing program but just black as the pic.
Why when converting from avi to mkv picture looks different?
By ma-fia in forum Video ConversionReplies: 10Last Post: 4th Nov 2011, 10:21 -
Fuzzy picture when converting ISO to AVI
By BassJunkie in forum MacReplies: 20Last Post: 24th Jul 2008, 10:46 -
Converting .WMV to .MPG and losing audio/picture
By frenchdb in forum Video ConversionReplies: 1Last Post: 29th Jun 2008, 20:42 -
After converting FLV to AVI, there is no picture, just sound!
By lowfell in forum Video ConversionReplies: 3Last Post: 22nd Apr 2008, 15:48 -
SVCD: Picture is not completely displayed during playback
By czerro in forum Authoring (VCD/SVCD)Replies: 5Last Post: 5th Nov 2007, 13:53
