Hi, gang -
I bought the Panasonic DMR-E80HS and am loving it, but have been confused by the High Speed recording setting.
If I understand correctly, when dubbing from the HD to a DVDR at High Speed, the DVDR must be recorded at the same resolution/speed/quality (XP/SP/LP/EP) that the HD recording was made, with no other option. Some posts I've seen on this board seem to indicate that High Speed dubbing is superior to realtime dubbing since the programs are not "re-encoded" in the process.
If I've decided that LP recordings (4 hours) are an acceptible compromise quality for television programs, which will yield me the better picture?:
* record to the HD at XP, dub to DVDR at LP in real time
* record to the HD at LP, dub to DVDR at LP with high-speed dubbing
For that matter, if I have a 2 and a half hour movie, my first impulse would be to record it with Flexible Recording (giving me a part-SP, part-LP recording). But does the re-encoding diminish the picture enough that it'd be better to do a High Speed LP dub?
Advice is much appreciated,
Tony Tower
Results 1 to 13 of 13
Originally Posted by Tony Tower
Originally Posted by Tony TowerPinnacle Studio 8 and DV home video editing (ver.9 already home) -
The advantage to recording at LP on the HDD and then high-speed dubbing to DVD is that it will only take 56 minutes as opposed to four hours (for four hours of content) if you do it real time.
FR sets the resolution and average bitrate based on the amount of time you assign to the recording. Any FR under 2:10 will be assigned the SP/XP resolution, but the average bitrate will be assigned to fill a DVD. A FR set to 2:11 or more will be given the LP resolution (about S-VHS quality), but the average bitrate will be higher than it would be for an LP recording, if the FR is set to less than 4 hours.
If you have a 2:30 movie recorded in FR, you will get an LP resolution recording at nearly twice the average bitrate of an LP recording. -
Okay, I guess I misspoke on how FR recordingn works. Thanks for the clarification.
I'm still wondering though, does the increased bitrate on an FR dub outweigh the quality loss due to re-encoding? For a 2:20 movie going to DVD-R, will an LP recording encoded once look better than an FR recording encoded twice?
- Tony Tower -
Please let us know your results.
Originally Posted by donpedro
Best,
Tony -
Tony:
Why not record to the HDD in FR mode in the first place? You will avoid the re-encoding, and still end up with a file that you can high-speed dub to the DVD. If the recording time is anything less than 4 hours, the quality will be better than LP would be.
Do I understand what you were thinking of doing? Were you wanting to compare (1) recording at LP and high-speed dub to DVD with (2) XP recording with real-time dub at FR to DVD? I think the result would depend on how long the ultimate recording that you would transfer to DVD would be. If the content is close to 4 hours, I bet (1) is better, but if it is closer to 2 hours, (2) would be superior.
However, I think recording on the HDD at FR and high-speed dubbing is the best of both worlds, although you must know how long the final recording is in order to set up FR. -
Originally Posted by doxtorRay
The hitch is that most of my recordings are going to be TV shows (5 separate programs, each recorded on different days). So FR doesn't help me there, as far as I can see. If I record each day's show at FR, each show would be "ideal-sized" to fill a DVD-R by itself.
And the theoretical movies I'm doing are probably backups of my laserdiscs where side changes are an issue. Can one pause an FR recording? If not, I'll probably try doing an FR recording of the laserdisc by setting the time to "running time plus 10 minutes" to accomodate side changes and then edit th dead space out after the fact. I wouldn't get the absolute maximum bitrate, but close enough.
Has anyone tried this? I plan to soon, and will report back. But just wondering what others have done when recording laserdiscs. . .
Best,
Tony Tower -
For my money, the quality is slightly better doing a LP on HD highspeed dub to DVDR than doing a realtime LP dub of a XP recording on the HD (enough initials there for eveyone?).
The downside is that I got used to watching the shows on XP first and then archiving them at LP, so I sort of miss seeing "new" shows all crisp and clean. The upsides are (a) quicker dubbing time and (b) my HD now holds quadruple the number of hours (since my initial records are now at LP instead of XP).
I guess I can always watch new shows live. . .
- Tony -
That is another coffee. To capture couple of episodes during couple of weeks, edit out commercials and then burn it on DVD ??? I would go with XP on HD and then burn is quality that I need. I don't know how it would look like but it sounds best to me.
You are going to be pioneer with this testPinnacle Studio 8 and DV home video editing (ver.9 already home) -
a few answers and comments:
I don't think you can record in FR mode and and utilize high-speed dubbing (at least according to my e100h manual). Also, FR mode on the HD will be based on a 4.7 GB disk and not what is left on your HD. Commercials that will be edited later will take away from you potential bitrate/resolution as the HD considers them, too. However, XP mode on a HD will result in an XP quality original to re-dub regardless of length (provided you have the space on your HD). Also, my e100h will only non-stop timer record up to 6 hours before pausing to begin a new session. I'm assuming this is because of the above 4.7 gb consideration built in the programming. It will continue recording as a new title after a brief pause. But if the pause falls in the middle of a show, it will still play continuously if you dub them back to back, but with this very slight pause (akin to using the "Divide Program" function). It will also show as 2 titles on the menu.
To capture couple of episodes during couple of weeks, edit out commercials and then burn it on DVD ??? I would go with XP on HD and then burn is quality that I need. I don't know how it would look like but it sounds best to me. -
REad my new guide here:
https://www.videohelp.com/forum/viewtopic.php?t=184722
The best way in my opinon to do it is, that you know a typical show is around 42-43 minutes after cutting out comercials. You should know how many minutes the program is once you edit out the commercials. Add the minutes up and either record in FR mode or use the LP mode. For example. Four 43 min shows = 172min= 2 hours and 52. I believe LP mode is upto 4 hours, so in this case I would record in FR because I should get a better result; there's still an hour and 8 minutes left, so you could record 1 more program if you use lp mode, if you don't then it's a waste of space because the space is not going to be used so that is why you use FR mode to use the whole space. Even go over a few minutes if you have to. Look at my guide and good luck. (I'm still fine tuning it) -
Well, I recorded a 3 hour,five minute program to the HD using FR mode. I then highspeed dubbed the program to a DVD-R, and it seemed to work swimmingly - used up the entirety of the disc space. If it had been an LP recording, there should have been some leftover space.
Looks good for now.
- Tony
Panasonic DMR es10 working question
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 24th Mar 2012, 18:02 -
Help with Panasonic DMR-E80HS ... need to save home videos.
By Hollywood_12 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 1st Dec 2011, 22:36 -
Panasonic DMR-ES10 - Audio Quality?
By Kryzon in forum DVD & Blu-ray RecordersReplies: 10Last Post: 29th Dec 2009, 19:17 -
Panasonic DMR-E80HS DVD burner
By MDR365 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 16th Oct 2008, 10:38 -
DMR-EH50 High Speed Dubbing
By jjis in forum DVD & Blu-ray RecordersReplies: 1Last Post: 30th Jan 2008, 14:45
