I've been thinking that a +- burner is the way to go, but now I'm wondering if we're better off getting a + (only) burner. If we can change the bit setting to make a - player recognize a + DVD, then I'm not sure I see the advantage of getting a dual format.
Both my DVD players (Cyberhome CH500 adn Mintek 2110) play the + format. Would there be any other reason to get - ? Just in case that's the standard that's adopted over time (like Beta/VCR) and I get a new DVD player?
I would think that even if the - standard is adopted (BTW, IMO the + will end up being the standard that gets adopted), how likely am I to want to need the + DVDs in a few years? Mostly, my DVDs will be (by then obsolete) data with a few movies here and there.
I'm looking at + burners for < $100 and I know the NEC duals aren't much more, but they're picky. I'm thinking its better to get a great single format than a so-so dual format.
Comments? Do I have this all wrong?
Results 1 to 21 of 21
The 2 big advantages to dual format are:
1) You can burn whatever is available/on-sale.
2) You can burn what works in your player (although you can get an Apex that plays anything for $40).
Everything else comes down to support and warranty.
Personally I'm picking up one of the new NEC dual format units for $116 out the door. It's just hard to beat that price/performance point. Feed it some nice 4x +R Riteks and its off to the races....To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I'm a big fan of Ricoh type burners and bitsetting.
Never had compatibility problems.
However I just bought a NEC1300A and helped installing it for a friend this weekend.
Flashed to 1.08 autoreset firmware and burned some Ritek G04 DVD-R and PackardBell DVD+RWs. All play well on two standalones we tried.
We are satisfied so far.You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
thanks for the replies.
I'm really interested in the conceptual intellectual question of whether it makes any difference to have a dual format burner if one can make a + appear to be a - via bit setting, thus removing the issue of player compatibility.
I see that there's the issue of media being on sale, but let's assume the sales cover both + and - as that's been my experience. Then, what's the advantage of dual format over bit setting?
Is it all marketing hype? -
IgotZZhere,
You pose a question which has been pondered by several people here and in other forums many times.
By using DVDInfoPro and suitable burning software, together with Ricoh burning hardware, the issues of rejection on book-type are nullified. Indeed via DVDInfoPro etc I have proven (to myself at least), in a limited fashion, just what you ponder. I have both a Ricoh and Dual Lite-On burner and to be honest I feel more confident in using "ROM bit-set" +R discs for home movie DVD distribution. Being part of the evolving development of DVDInfoPro has seen the dispelling of myths regarding large differences between + and - formats in a physical player/playability sense. Setting a +R disc as -R book-type gives the same sort of player acceptability as genuine -R discs, subject to media quality. It is well known that -R disc users suffer from available cheap media issues, but the question is more complex when same media/software with different burner are used. This same relationship of burner/media/software is becoming more prevalent in the +R burning side also, as more manufacturers produce +R discs.
In short you must decide for yourself, but I dare say that a "bit-settable" burner like the Ricoh MP5240 and good quality media (Ricoh, MCC) produces a very acceptable and playable resulting disc. Save some money and buy cheap -R media and a Pioneer A06 and you may well get the same results in your own situation......Ponder some more.
Regards
Studebarc 8) -
Why would you have to change these bit settings other than a problem with the drive reading the media? If that is the case, wouldn't that mean trouble down the road?
Originally Posted by videobruce
"Some players report a disc error when a disc is loaded that is not marked as a "DVD-ROM" or "DVD-R/W" disc in the compatibility bits. Ususally, these players are physically able to read the disc (since DVD+RW reflectivity is identical to that of a dual layered DVD-Video disc, which all players must be capable of reading), but their compatibility problems are due to different interpretations of these bits in the various firmware versions. In most cases, the problem can be solved by updating the firmware.
When a firmware fix is unavailable, or when you want to increase changes of playability when you give the disc to others with an unknown player, you could solve the issue by marking the DVD+R or DVD+RW disc as a DVD-ROM disc."You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
thanks for the info everyone. I like the idea of going with a + burner. I personally don't think that - will get too far, but hmm.. I have a betamax in the garage so maybe I should bet the other way.... Probably a A06 is in my future, or maybe a plex if I can get a hot deal on it.
Originally Posted by tompika
Thanks! -
Its about "plus" medias.
The booktype is pre-recorded on "minus" discs and can not be changed.
They don't need it anyway.You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Originally Posted by IgotZZhere
That's why I hedged with a dual burner.fREBieware- you get what you pay for. -
I see. Well that sux for me. I was hoping I had come across something. Thanks for the quick and helpful response.
Just bought a Ricoh MP5240A burner it comes with it’s own bitsetting software this is my second Ricoh & burned using Dvd-Rom book it will play in everything.
Over at the dvdplusrw.org forum, someone asked, "why don't the manufacturers just set the DVD+R/RW to DVD-ROM by default?"
The HP burners and Philips recorders already set DVD+R to DVD-ROM by default so it would make sense to set the DVD+RW to DVD-ROM as well, don't you think? We all want maximum compatibility, right? -
I believe the actual question was:
Originally posted by Loobster
I don't know why manufacturers of DVD+ drives even bother to allow bitsetting. Why not just burn DVD+R as DVD-Rom by default? Why would you need bitsetting then? -
Originally Posted by Gil T Pleasure
Any of you have friends at Plextor's?You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
I bougth a dual format for 2 reasons:
+ You can get cheaper media (DVD-R is the cheapest)
+ You can get dual side DVD's (DVD-R)
+ Compatibility. Most recent DVD players like the DVD+R, most like the DVD-R. I have one that likes both.
+ I'm not sure about this one, but DVD-R is more oriented for backup data, and DVD+R is more for video.
Maybe you can get a cheaper DVD+, but the media is more expensive, just check the prices.
I just got a Plextor 708a and it works great. I upgraded from an HP (I paid 600 two years ago), it worked fine, but it only supported DVD+RW. -
Originally Posted by jgandaraWant my help? Ask here! (not via PM!)
Take a look at the NU tech DDW-081 it will burn 8x with DVD+R AND....(it's a big one)......it allows bitsetting.
https://www.videohelp.com/forum/viewtopic.php?t=184895&highlight=
It cost $155USD http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=174502
Anybody want to buy a slightly used Optorite DD0203? -
Originally Posted by -jsl-
Maybe because I don't use DigitalMatrix, CMC, SKC, etc.....?You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40 -
HDC setting question, 2 pass + manual bit rate
By jsbenson in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 19:15 -
Which video format has the best about everything ( quality, bit rate...) !?
By coxanhvn in forum Newbie / General discussionsReplies: 17Last Post: 3rd Sep 2008, 21:02 -
is the format important when i.........
By andersonmilltexas in forum Authoring (DVD)Replies: 3Last Post: 7th Dec 2007, 23:28 -
MPEG 1 -bit stream format
By banbuzz in forum ProgrammingReplies: 2Last Post: 25th Aug 2007, 12:36
