  1. I'm using DVD-lab 1.1.
    I want my menu to be set up with a couple different segments and was wondering if i can have like "Video 1" "Video 2" and have them play then go back to the menu and also have a "Play All" button that will play both of them before it goes back to the menu without having to put both videos on the disc twice.
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    it can be done, but not easily - if your videos will fit on the disc twice, that's the easiest way to do it.
    otherwise, it involves jumping through some hoops with IFO Edit.
    check the official DVD Lab Forums at www.mmbforums.com, there's some threads with links to instructions on how to do this without duplicating video.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. Check the guides - there is one for this....
