I see the Panasonic Recorders have 5 recording speeds,
FP=will fit best quality to fill up DVD
XP=Best Quality???
SP=High Quality 1 Hour (Assume 8000MBps)
LP= Medium Quality = 2 Hour (Assume 4000MBps)
EP=Low quality = ? Hour
I have 2 questions, is the EP speed 4 or 6 hours??? (Assume is 4 hour = 2000MBps, 6 hour = 1500MBps)
And what is XP, I assumed SP (1 hour/8000MBps) was pretty much best quality, SOoooo is SP = VBR and XP=CBR??? or is it above 8000MBps??? or is none of those, what exactly is XP (if it can be explained)?
Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge.
Sorry, found online PDF of machines... Was wrong across the board...
XP = High = 1 Hour (assume 8000MBps)
SP = Normal = 2 Hour (assume 4000MBps)
LP = Long = 4 Hour (assume 2000MBps)
ELP = Extended Long = 6 Hour (assume 1500MBps) YECH!!!
I thought that many of these units only had 3 quality settings (maybe the earlier models???)Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge. -
You can of course check the bitrate with the E80/E100. I've found that XP recordings run 7 - 10 MBps, SP 6 - 8 MBps, FR is something in between depending on the source material. What I want to know is how much the bitrate will change if you choose to not use the default recording settings (since all of them are adjustable)...
Originally Posted by gcutler
If you use FR then I think it will stay full D1 until somewhere around 2 hours and 15 minutes (or less).
- John "FulciLives" coleman"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Originally Posted by FulciLivesCendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge.
panasonic bluray recorder problems with grinding noises when recording DVDs
By hargels in forum DVD & Blu-ray RecordersReplies: 1Last Post: 10th Apr 2012, 16:52 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
Software or settings suggestions for screen recording
By Cassel in forum Newbie / General discussionsReplies: 11Last Post: 28th Sep 2009, 18:21 -
recording settings
By devdev in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Mar 2009, 13:46 -
replace audio with quality MP3 recording from other recorder
By daka in forum AudioReplies: 5Last Post: 26th Jun 2008, 20:08
