  1. Hi, I have a couple of encrypted dvdr s...
    My question is; is there anyway to decrypt it without reburn it?
  2. No.. You can't change the data on a DVDr. To change it you have to move it to a new one.
    By the way, I do not believe a DVDr can be encrypted. It may have macrovision set.
    I mean it in the nicest way.
  3. Hmm... You could try disabling Macrovision on your player.
    Other than that, you're out of luck
