I was trying to backup Star Trek DS9,season 5,disk 1. I could not rip it to my HD. I tried DVD Decrypter and Smartripper,in four different DVD-Rom drives,but every one would hangup at the same point,about 50% thru the rip. It even froze in my standalone player at the same point.
I knew the problem was in vob #4 so I tried ripping vob #4 in my Pioneer DVD recorder,while slow it was able to the complete without any problem.
I then ripper the rest of the files in file mode with DVD Decrypter and then had DVD ripped completely to my HD.
FYI
Did you try playing it first to unlock it? Are you sure it plays fine all the way & is it clean?
It's dirty/scratched. Clean it with toothpaste, or tell your ripper to skip after 5 failures.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Ripping speed for dvd-r
By vcd4me in forum DVD RippingReplies: 10Last Post: 22nd Apr 2011, 05:45 -
DVD Fab v/s AnyDVD Ripping Speed
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 25th Mar 2010, 13:04 -
Does SATA make big difference for DVD burner?
By sdsumike619 in forum ComputerReplies: 6Last Post: 28th Nov 2008, 19:21 -
Would using DVD-R instead of DVD-RW make a difference?
By Mee_Too in forum Newbie / General discussionsReplies: 3Last Post: 8th Sep 2008, 18:13 -
How can I make my dvd burner overclock to a faster speed?
By goheadtry in forum Authoring (DVD)Replies: 7Last Post: 2nd Dec 2007, 19:11
