I recorded from my DV camcorder,now I need to make it into dvd format
then I want to use dvdshrink and put it on 1 dvd..what is the best way to make it into dvd format..I used ulead studio to record it but the program will not let me use the disc formatting tool to make the vob files etc...
Results 1 to 14 of 14
use the DVDRhelp Bitrate Calculator (in the Tools section) to find a bitrate that you can fit 3 hours on a disc, then use an mpeg-2 encoder such as TMPGenc or MainConcept to encode your avi to mpeg-2 at that bitrate.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
It sounds like you need an authoring tool. Check the list of them under tools to the left. I use TMPGEnc author, but there are freeware ones also. Haven't used Shrink sucessfully, but I believe it works after authoring. Alternativly you can encode with TMPGEnc or Mainconcept and then author. Check the guides.
Mentioning DVDShrink implies you don't know what your doing.
You need to:
1) Capture footage from camera to Computer
2) Edit footage
3) Encode Footage to a DVD Standard
4) Author DVD
Sounds simple, and can be, or it can be very complex. It just depends on how fancy you want to get. Search on the 4 basic subjects(you have 4 distinct steps you need to do) and go from there.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
the avi files are seperated into 4 files,does the author program put them all together?
No you would need to join them yourselves before or after you authored them (much better to do it before) this can be done using virtual dub and you can find a guide on this on the left.
It is taken for granted that you can do certain things on your own. These include, but aren't limited to reading english, being able to download, and beign able to install software. Generally speaking this involves the use of winzip/winrar/winace software.
Being able to use the seach page on this site will make your life incredibly easier.
VDUB : Did it not install, or did it not run?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
sorry I meant download from the site..have to look elseware..right now im using video studio to make a .iso file from the 4 avi clips I have..just tring it out..figured I can do something with a iso file.I tried to make it formatted for dvd but it failed the process.
Sigh.
You can't do anything with an AVI file and a DVDR, except store them for longterm. Your not reading.
You have to convert the AVI's before any DVD player will play them. That's waht TMPGENC / CCE / Mainconcept is for. It makes an MPEG2 file that's DVD complient. Audio is a seperate issue (DVD standard for NTSC land is PCM or AC3/5.1, not mp2/mp3).
We skipped over editing your footage.
Once you've converted, you have to author the DVD (build the files and structure that's on a DVD).
You are trying to do a medium-hard project with no prior experience. However, it's been done to death and the guides ahve step by step examples of everything you need to do.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
ok.. im encoding with tmp authoring program or should I use the reg tmp program
avendo -
TMPGenc (encoding program) and TMPG DVD Author (dvd authoring program) are two different programs - make sure you are using the right one for your task.
as for Virtualdub, go to www.virtualdub.org and find the links to the download.
it sounds like you need some remedial education before you jump into authoring - you should read the "What Is" sections at above left, also the How To sections, and check the Glossary if you find terms you are unfamilair with.- housepig
Housepig Records
out now:
I have looked at the read me's and how to's and there is alot of stuff..thats why I asked you guys here on the froums..I was looking for a step by step from someone..
How to get 10 hrs SD footage onto BD?
By ruffhouse in forum Authoring (Blu-ray)Replies: 52Last Post: 16th Nov 2011, 14:25 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 23:42 -
Why does it take 10 hrs to encode a film using handbrake?
By jones24 in forum Newbie / General discussionsReplies: 8Last Post: 12th Aug 2009, 16:53 -
8 hrs of Avi to DVD with Menus
By randolphsw in forum ffmpegX general discussionReplies: 10Last Post: 7th Feb 2008, 20:31 -
shortest way to encode 5.5 hrs of avi's using tda3
By cduval04 in forum Newbie / General discussionsReplies: 4Last Post: 7th Jul 2007, 13:38
