I'm not a newbie of this site I just don't post alot I try to search here and all over the net to find answers.
Well wanted to know if there is any dvd that can't be backed up period.I just go a sony 510a dual and started backing up my dvd collection. I use DVDshrink
DVDdecrypter
Nero![]()
Thanks,
slopokey
this is one of the best sites i check it almost everyday
In general, anything that's digital can be copied. So, to say that any DVD (or at least the content of) can be copied can not be proven untrue. It may be harder or easier, but not impossible.
/Mats -
I've had no luck with "Independance Day" (R4)
I just can't rip it to my HD, ah well no great loss. -
What software are you using to rip.
Minchjp - And... do you have enough space to rip to? I see you have 15 Gig listed in your profile. That fills up quickly. Perhaps check that? :c)
There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
And if it is scratched, it may barf. You need to tell your ripper to skip over the error. Search 'cleaning dvd' for tips on solving skips.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
If you are still having problems with a specific disk, try again with another ripper. I have had great success with SmartRipper.
Just what is this reality thing anyway?
Backed up VHS tapes on one DVD, need to create menu DVD
By perceptionist in forum Newbie / General discussionsReplies: 6Last Post: 11th Mar 2011, 18:57 -
Have you successfully backed up the Casino Royale?
By coody in forum DVD RippingReplies: 122Last Post: 27th Sep 2010, 03:21 -
Panasonic Blu-Ray player won't show Backed Up DVD or.....
By Scooter_NJ in forum DVD & Blu-ray PlayersReplies: 18Last Post: 3rd Sep 2008, 15:37 -
No main audio on backed up Blu-Ray BD-R
By ravo in forum Blu-ray RippingReplies: 2Last Post: 8th Aug 2008, 09:21 -
Working with m2ts files backed up from Blu-Ray disc
By Lovepeaceguru in forum DVD RippingReplies: 11Last Post: 15th Dec 2007, 07:55
