I regulary download movies off the web (usually 700MB Avi/DivX ect files). As I have a DVD writer I usually encode with TMPGEnc having unlocked the program with newgen's guide "how to fit movie on 1 CD". So basically what I do is set TMPGEnc to encode the film to approx 4GB in size. I use CBR as oppose to 2 pass VBR settings due to the time 2 pass VBR takes.
I'm wondering:
A/ is there a better way to encode the movies and could I acheive better quality without the encoding process taking 36 hours. Would It be better to encode the 700MB avi/DivX ect to a 700MB Mpeg2 using 2 pass VBR?
B/ Am I wasting my time encoding a 700MB file (avi/DivX ect) to 4GB's? At what biterate do you cease to notice a difference in quality?
Thanks in advance.[/url]
Tosti thanks for the reply. I am aware that the final Mpeg2 depends on the quality of the origional. I wondering though could my encoding settings in TMPGenc be better (am I wasting my time at present). Should I use 2 pass VBR and encode to a smaller file (say 700MB AVI to 700MB MPEG2 so that it doesnt take 36 hours) instead of encoding my Avi to a 4.2GB Mpeg2 file using CBR?
My settings are more or less the same as this guide except that I'm using CBR. -
A 700Mb mpeg-2 will probably not look as good as the original 700Mb avi. My suggestion is to use 1/2 D1 resolution (352 * 480) (more compatible with DVD that SVCD), use 2-pass VBR or Cq mode and you should easily get 4 hours on a DVDr with quality as good as you are getting now.
bugster,
Thanks for the reply.
Thanks again. -
Instead of asking 'How', you need to ask 'Why'. 1 CDR AVI file will never convert to an acceptable DVD. Generally speaking you only have VCD resolution in something that small, so naturally it looks like crap at DVD resolutions. If it has higher resolutions, it's so over compressed you can't ever get rid of the artifacts, which means you will be burning bitrates when it's converted to mpeg2.
Don't bother. And don't tell me you have magically found a Public Domain video that's 700 MB's.
Some things will never look good when converted to DVD. It won't ever look remotely close to the original DVD (which you should work from in the first place). Even 1/2 D1 resolution is often higher res than the AVI. Look seriously at some other resolutions/options.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
Blueray to a 700mb .avi file
By withmenilu in forum Blu-ray RippingReplies: 1Last Post: 24th Jun 2009, 05:07 -
Shrinking an AVI file from 1.4GB to 700MB
By DVantrease in forum Video ConversionReplies: 5Last Post: 28th Mar 2009, 19:11 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 21:22 -
Trying to encode DVD to DIVX/AVI or h264
By cassavetes in forum ffmpegX general discussionReplies: 11Last Post: 25th Jun 2007, 10:46
