ive been having a problem with quicktime playing video but not audio (see my Alternate XVID Codec thread). so my question is, is there a way to add a seperate audio track to quicktime if i were able to extract the audio file from the movie using FFmpeg or something? let me know, i woudl appreciate it greatly
Sure... you can add a new audio track in Quicktime for the same movie just as easily as you added another thread to this forum regarding your same problem. 8) 8) 8)
Seriously though...
This can be done.
Once you have your audio track all set, just go into quicktime and SELECT ALL, then copy your audio track to the clipboard.
Then go to your movie track, and select all and click on EDIT --> ADD.
That's it.
If file size is no object you can always convert the audio only to PCM by way of Mencoder, which will then play back directly in Quicktime with no further modification.
If Quicktime is no object, just use VLC. Download the program at www.videolan.org and launch it one time. Then go to your .avi file in the finder and hit CMD+I to get info. Under OPEN WITH, change it to VLC then select CHANGE ALL. Then all your .avi files will open in VLC and your playback problems are gone forever.
Hope this helps. -
too late. i already tried and perfected your previous method. but i may still give the mencoder method the old college try. thanx for the help man!!
by using Mencoder you will only be changing the audio from MP3 to WAVE and keeping the video in tact. This is a VERY fast process and would solve your problems in one step.
Glad to help... just let me know if you need anything else.
Converting to MKV plus adding diff Audio & Subtitle tracks
By evile1690 in forum Video ConversionReplies: 3Last Post: 5th May 2010, 00:37 -
Adding new audio tracks to MKV
By FPK in forum Newbie / General discussionsReplies: 0Last Post: 24th Apr 2010, 09:39 -
Add an 2 video/Audio tracks to a .mov file without using Quicktime
By thomas31388 in forum Video ConversionReplies: 0Last Post: 24th Sep 2008, 15:35 -
Adding new audio tracks to MKV?
By levon in forum AudioReplies: 1Last Post: 27th Mar 2008, 18:02 -
--> Adding Audio CD Tracks to DVD audio ? <--
By MJPEG guy in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 16:45
