Poll: Which software do you use to burn backups of DVD movies?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 21 of 21
  1. Which software do you use to burn backups of DVD movies?
  2. 1. DVD Decrypter ISO writing
    2. RecordNow DX 4.61
    3. Nero 6 Burning ROM/Express
    I use these three programs
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
    I don't burn backups really, but I do use Nero for DVD-Video.
    May 2003
    Pal Realm
    I don't burn backups either. But I burn and re-burn through my authoring app, so - none of the above.
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
  5. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    EZ CD CREATOR CANNOT BE USED BELOW 4 GIGS...
    correct me if i'm wrong but without enuff 'stuff' in the video ts folder ..it fails to finalize making SET TOP PLAYBACK PRETTY IFFY!!!!
    otherwise..my faves
    best..STOMP
    second...PRIMO
    buggy...NERO
    for example..when NERO EXPRESS does a DVD to DVD copy
    belive it or nuts..it gives the copy the NAME "NEW" regardless of what the original disc was called!! Under WIN2K with 6.0 this is!! but
    NERO BURNING CD ROM works to keep the disc's LABEL intact
  6. vcdeasy.. not on list..
    The electronic components of the power part adopted a lot of Rubycons.
  7. Member rhegedus's Avatar
    on the jazz
    Nero v 5.5.10.28
    Regards,
    Rob
    Aug 2002
    LightCycle Grid
  9. RecordNow Max Rules! Especially for DVD+R
    I've seen Nero mess up DVD+R burns for many people (uses the wrong booktype).
    Aug 2002
    LightCycle Grid
    The best tool by NERO is their marketing tool.
  11. Member GKar's Avatar
    Jul 2003
    In the corner, on a stool
    Nero has always worked flawlessly for me.
  12. I always use CopyToDVD. It's never failed me. But recently I've been using CloneDVD, and I have no complaints with that either.
    Oct 2002
    Texas
    I use VCDEasy mostly. Nero on rare occasion.
    Don't squat with yer spurs on.
  14. Big Nero Fan here
    If it's wet, drink it
    My DVD Collection
  15. VCDEasy for all my VCD authoring / burning. Nero for anything else - which ain't much.
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
    Apr 2003
    1. DVD Decrypter For Ripping - (Win Xp Running under vmware - Linux)
    2. Instant Copy For Shrinking - (Win Xp Running under vmware - Linux)
    3. XCDroast for Burning - (All Linux)
    These are the thing I use for now. As soon a a linux equiv comes out I'll switch to that.
  17. Nero 5.5.10.54 is great. I've used Nero (various versions) for about 5 years now and never had a problem that I didn't cause myself. The only fault I can think of is it doesn't always get along with other burning software.
  18. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    I've never had a burning problem with any software that I've used, But Nero is my favorate.
  19. New to this site and wish I found it before I bought DVD X-copy but that's what I use. Saved a lot of the kids' DVDs just in time.
