I have an AVI file I want to convert to CVD using AVI2SVCD and CCE. When I play the file using media player, bs player, or Power DVD, it plays great picture is just right and the sound is perfect. But, whe I load the file into Virtualdub, I get "Cannot Determine File Type" error. SO I can't even tell what type of file it is. If I load it into TMPGEnc, I get an error, and CCE just hangs. Now what can I do? As I said the file plays perfectly on playback, both audio and video, so I don't think it is a codec problem, although I am not too sure, which is why I am asking here.
Any guidance would be greatly appreciated!
training42,
You can try VirtualDub Mpeg2/AC3 version. Not sure where you can download it but do a search. It's around.
Cheers,
feeras -
Thanks for the fast reply's. Right after I posted this, I had a hunch, which GSpot confirmed...It was an OGG media stream with DIVX 4CC with ogg audio. I have messed with ogg files before, but this was the first time I have ran into one with an .avi extension, I have only seen the .ogm extension. Anyway, I decompressed it with the decompressor from avi2vcd, and virtualdub picked it right up. Now I can convert to CVD.Originally Posted by ZippyP.
Thanks for the help, and if anybody else has run into problems with ogg files, go here for help http://sigmus.cjb.net/
Help! Cannot rip this DVD - wierd problem...
By Comfy in forum DVD RippingReplies: 2Last Post: 8th Dec 2009, 11:10 -
WIERD DVD data disk problem
By bruinflight in forum Newbie / General discussionsReplies: 24Last Post: 25th Sep 2009, 00:53 -
wierd playback issue in MPC
By fix25 in forum Software PlayingReplies: 0Last Post: 26th Oct 2008, 17:03 -
More wierd Vista behavior...
By ahhaa in forum ComputerReplies: 2Last Post: 28th Jun 2008, 21:05 -
Wierd REWIND Problem... on standalones only!)
By taboo in forum DVD RippingReplies: 4Last Post: 16th Feb 2008, 22:29
