Now, let me tell you my intentions. I want to convert my Star Wars Trilogy Widescreen LD onto my computer in the best possible quality. And then put it on DVD. Now, I have the putting on DVD task pretty much covered. My question is this. I have a ATI TV Wonder VE Card that I planned on using and then recording the movies with the Digital VCR set to DVD Format for the best possible quality. Now, all the software I would be using is the updated Media Center by ATI. Does anyone know of any other software I can use which will give me better quality? Thanks.
this is almost required reading for what you're attempting:
https://www.videohelp.com/forum/viewtopic.php?t=102812 -
I capture from LD using the capture tool in the MainConcept software, using the HuffyUV codec, then encode using the LSX-MPEG encoder suite.
Convert (rip) DVD to AVI
By enchanted in forum DVD RippingReplies: 6Last Post: 12th Jun 2009, 05:55 -
Rip a DVD to AVI with mencoder
By Cazz in forum DVD RippingReplies: 17Last Post: 28th Feb 2009, 11:00 -
Rip DVD+RW disk to AVI
By Tbag in forum DVD RippingReplies: 1Last Post: 5th Nov 2008, 18:26 -
DVD Rip to AVI in queue
By Badazz in forum DVD RippingReplies: 2Last Post: 10th Dec 2007, 18:03 -
how to rip audio from DVD and AVI without re-sampling
By ted demen in forum AudioReplies: 9Last Post: 23rd May 2007, 11:23
