I just started using a card that captures video in mpg (instead of avi). I captured some video and burned it to a DVD. Before watching the DVD I noticed that the image on the monitor had black space at the sides of the picture and some noise at the bottom. I loaded the video into TMPGEnc Plus and used the 'Clip Frame' option to take out the black and noise- then re-rendered it to a new mpg which I burned to a disk.
Then I looked at both disks- they look the same. I played both disks on 2 standalones and 2 different TVs. The noise and black spaces that were visible on the computer did not appear on the TV screen.
Before I burn any more I'd like to know why. I don't want to burn a bunch of disks that don't appear to have the black and the noise only to find out later that it shows up again on a different standalone or TV combination.
Anybody know? (I'm using a Videoh! PCI capture card at the moment).
NTSC TV ( And probably PAL) use 'overscan" that cuts off the sides and tops of what you see on a computer monitor. You should check your finished project on TV if that is your final destination. If you plan to encode for computer only, do the trim. TV does'nt generally need it.
Imagine me, another problem w/ Vegas! Capture vid & render, no mp4 save?
By damonj_3 in forum Newbie / General discussionsReplies: 2Last Post: 12th Sep 2011, 12:01 -
MPG movies show shorter time then actual... help needed
By wolf_ast in forum ComputerReplies: 5Last Post: 30th Mar 2011, 20:52 -
DVD to MPG/AVI/H264 for editing - desperate help needed
By BertRito in forum Newbie / General discussionsReplies: 19Last Post: 17th May 2010, 23:46 -
capture without having to render
By sfischer in forum MacReplies: 1Last Post: 6th Mar 2008, 12:09 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31
