How would I go about ripping from DVD to my hard drive that would produce a single mpg file that I could use with TMPGEnc DVD Author and author at a later time? I have read where it is possible to rip and compress while keeping 80% and higher quality. I have used DVD Shrink and have managed to get some files down to around 1.5-2 gigs compressing it at about 40 percent, possibly higher while saving a good portion of the movie quality. Is it possible to decrease the total size of the movie even further, something under a gig while saving the quality to something halfway decent?
I failed to mention my goal was to back up my DVD collection onto my hard drive and then later combining 3-4 of those movies onto 1 DVD.
I think from what I have been reading that the correct termanology is DVD - SVCD? If that is the case would I need to dl DVD2SVCD or possibly something like VCDEasy? Do these programs produce a single mpg file?
thanks is advance. -
If you are trying to learn about these things... go for it.
However, I think you are taking a hard path so that you can save space. You are in for a bunch of work, and drive space is getting cheaper and DVDr is getting cheaper, and who knows, maybe a 300+ dvdplayer will be cheap some day.
Here is some of what I know. Read "What is SVCD" for more:
IF you convert from DVD to SVCD:- You will be changing the picture size
- You will be changing the Audio from AC3 to MP2
- You will be redoing the chapters
- You will loose the DVD menus
- You will loose the subs (depends on your player)
IF you then convert back to put the SVCD on a DVD:- You will (unless you do a lot of work) loose the subs
- You will convert the sound again
- You will loose the SVCD menus (if you made any)
- You will not be compliant (but most players will be ok)
DVD2SVCD is a great tool, but switching formats and then back is a lot of work to save some space.
Here is a good guide: https://www.videohelp.com/forum/userguides/167502.php
My only advice if you insist, is to convert to cvd which is a valid size for dvd, and keep the ac3 if you are in the US. MP2 is not standard/valid.
To answer, how to get a MPG from a dvd? Use DVD2AVI and then encode it with CCE or TMPGEnc. This is what DVD2SVCD does.I mean it in the nicest way. -
Many thinks for the info. All I needed was a nuge in the right direction. I agree SVCD is defiently not the way to go. Thanks again.
Originally Posted by lizardfish
The guide:
https://www.videohelp.com/forum/userguides/120021.php
Whole DVD --> single Mpeg2:
1. Start vobedit, click open, browse to 'VTS_01_0.VOB' in the 'VIDEO_TS' folder of your DVD.
2. Click 'demux', a small window opens, select 'demux all video stream', 'demux all audio streams', cllck 'OK'. (Selection depends on your own choice)
A m2v video stream and mpa audio stream(s) will be produced by vobedit. Multiplex them by TMPGEnc or else to a single Mpeg2 file.
Want simple tool for chapter links within single mpg file
By salring in forum Authoring (DVD)Replies: 2Last Post: 7th Jan 2011, 22:21 -
i have a question. DVD to a single avi/mpg.
By adan_4u in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2010, 23:22 -
DVDFab Platinum - rip into single Vob?
By nrishiraj in forum Authoring (DVD)Replies: 1Last Post: 19th Dec 2008, 17:33 -
Single Episode Rip with MINIMUM Re-re-re-re-compression - HELP!?!
By jdmba in forum DVD RippingReplies: 6Last Post: 8th Aug 2008, 09:45 -
Rip a DVD to a MPG file with selectable subtitles
By jjulio1 in forum DVD RippingReplies: 3Last Post: 1st Feb 2008, 01:24
