Hi all. Ok, I have over 600 scanned family pictures that I would like to stick onto VCD. Sizewise, obviously, these will easily fit, however, using Nero, it seems that the limit is 99 pictures, which seems ridiculous??? (I have used the guide on here BTW). So, anyway round this, or can someone suggest a prog that will enable me to put all these pics onto a cd?
"Manchester, so much to answer for"
Some programs have this 99slides limitation. But you can get around it by having several different slideshows operated from a single VCD menu. I use Ulead Pictureshow2 but there are many others. Check the "Tools" section.
Authoring DVD with embedded jpegs - Help
By RNBzie in forum Authoring (DVD)Replies: 4Last Post: 18th Jun 2011, 11:44 -
JPegs won't play on TV
By didikai in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2009, 18:04 -
Crop/Center jpegs for timelapse?
By tjubb in forum EditingReplies: 1Last Post: 14th Sep 2007, 22:39 -
Import JPEGS to Premiere
By videobread in forum EditingReplies: 1Last Post: 26th Aug 2007, 16:11 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 11:38
