I have seen many posts about sync problems but they deal with avi files.
Anyway, I capture as MPEG2 -- good quality. That file is in sync and plays fine in WinDVD. But after I encode it with TMPGEnc, the farther into the file, the more out of sync it gets. (some people mentioned theirs was out of sync the same for the whole video). The reason I tried TMPGEnc in the first place was because of the How-Tos. I thought TMPGenc sounded good. It was simple to use and recommended by many. I figured there would be others with this problem.
Anyone know what to do, I'd appreciate hearing it.
Thanks,
Paul
Re-encoding only results in lost quality and, in this case, bad sync. Why not just capture at your final resolution? That's the only suggestion I can think of.
"Art is making something out of nothing and selling it." - Frank Zappa -
The capture software doesn't have VSCD as an option. I have WinFast PVR software. Is there some other software that 'does it all'?
After conversion audio is out of sync
By videojunkie7 in forum Video ConversionReplies: 0Last Post: 23rd Nov 2009, 19:06 -
Audio Conversion out of sync
By Silsur in forum AudioReplies: 8Last Post: 13th Oct 2009, 18:45 -
mpg video conversion out of sync
By pettinej in forum Video ConversionReplies: 2Last Post: 14th Oct 2008, 21:49 -
Conversion to MPG puts video out of sync
By ral315 in forum Video ConversionReplies: 5Last Post: 5th Aug 2007, 20:18 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50
