Hi there
I currently have canopus raptor rt combined with premiere 6.5.
After I capture some files and edit them, than I want to put it on dvd.
I want to know what is the easyest way. It takes lot of time to save the preject as avi and then convert to mpeg-2 using tmpgenc and than writing on a dvd disk.
Isn't there some quality mpeg plugin I can use in premiere 6.5 so I can save it straight away in mpeg. By the way I did try som plugin that didnt have good enough quality.
Any suggestions??
Results 1 to 10 of 10
Elvar Birgisson
Iceland -
FRAMESERVE from Premiere to TMPGEnc.
https://www.videohelp.com/glossary#Frameserve
http://www.videotools.net/guides/guide_premiere_tmpgenc.php
Doesn't 6.5 come with MainConcept MPEG2 encoder??
Well it premiere 6.5 came with some mpeg decoder but I did't like the output so that is why I am searching for something else.
Thanks I will try that software you recommendedElvar Birgisson
Iceland -
MainConcept, Procoder, Cleaner 5/6/XL, CinemaCraft (CCE)
A TMPGEnc plugin for Premier is available at
http://www.puresoft.co.uk/tsunami/plugin.htm
I haven't used it myself, but I think it's available for trial as well
cheers
Scott -
Originally Posted by beammeupWant my help? Ask here! (not via PM!)
premiere 6.5 comes with the main concept encoder which is very good -- but there is an update for it (1.3) which you should install ...
http://www.mainconcept.com/adobempeg/downloads.html"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thank you very much for the info guys.
If I may also ask: I have a dv avi file and have loaded it to premiere 6.5. When i tried to export it to vcd using premiere's built in adobe mpeg encoder(mainconcept) it has no problems. but when i try to export it to dvd using again adobe premiere's encoder(mainconcept), the resulting picture is inverted.
Just updated to 1.2
Hope you guys could help.
tnx. God Bless -
I use Premiere 6.1 and have a Ligos 2.0 encoder that is a plug in for Premiere. I don't know if it works with 6.5, but it works real nice with 6.1. Export from the timeline to MPEG1, MPEG2, MPEG4. Quality seems to be pretty good also, but I don't have anything to compare it against either.
The dvd, if you build it to your hard drive, should be fine....
The Media Player has DirectShow problems with MPEG-2 codec
sometimes that forces upsidedown playback..
If you play the file you think is inverted over the network on anorther machine 99% of the time you'll see its the player not the file itself
The MPEG-2 plaugin native to premiere has been excellent for all my coversions but there are 5 differing plug ins I've tried 3 of
MPEG-MARVEL...works fine but doesn't handle AC3
LIGOS..Mpeg audio only (no ac3)
Digigami plug in...works fine, also no ac3 support
It seems you need XP Pro and Premiere Pro for AC3 files
TMPGenc Xpress 4 and Mpeg Video Wizard DVD VFapi plugin
By stanB in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 14:46 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
Premiere MPEG for DVD setting
By CircusAim in forum Newbie / General discussionsReplies: 5Last Post: 22nd Feb 2010, 11:23 -
Mpeg-4 to mpeg-2 for mac/adobe premiere pro......
By macbookuser in forum Newbie / General discussionsReplies: 1Last Post: 4th Sep 2007, 21:48 -
DGMPGDec plugin for AVISynth doesn't read MPEG file's audio
By Mark001 in forum Video ConversionReplies: 11Last Post: 9th Jun 2007, 18:07
