I'm not sure which of the log information is useful, so I apologize in advance for the long post... any ideas would be greatly appreciated.
Windows XP Professional 5.1 Service Pack 1 (Build 2600)
Processor info: AMD Athlon(tm) XP (1333MHz)
Memory Available to Windows: 523,760 KB
############################ Program Information ###########################
File Name: D:\Alcohol120\Alcohol 120\Alcohol.exe
Company Name: Alcohol Soft Development Team
Description: Alcohol 120%
Original: alcohol.exe
Product: Alcohol 120%
Trademarks: Alcohol Soft Development Team
Copyright: Copyright(C) 2002-2003 Alcohol Soft Development Team
Version: 1.4.7 ( Build 1005 )
Date: 2003/10/06
File Name: D:\Alcohol120\Alcohol 120\alcoholx.dll
Description: Alcohol virtual device control library
Original: alcoholx.dll
Copyright: Copyright (C) 2000-2003
Version: 3.41.0 ( Build 0 )
Date: 2003/09/28
Hash: 8da72365a2e663e16d6f06b557f69231
File Name: D:\Alcohol120\Alcohol 120\devsupp.dll
Description: Alcohol Software Device Capability Library
Original: devsupp.dll
Product: Alcohol Software Device Capability Library
Version: 2.3.3 ( Build 1003 )
Date: 2003/10/06
Hash: 39bd4a013241eeb476b7321feec5452e
########################### Options Setting ###########################
Devices control interface: Default Driver Control Interface
CPU Priority Level: High
Memory Buffer Size (MB): 128
Examine the accuracy of data read from physical device: Yes
Turn off "Auto-Select best write speed" function if possible: No
Overburn disc(s): No
Fill memory buffer before recording discs: Yes
Ignore Media Type: Yes
RMPS (Recordable Media Physical Signature) Emulation: No
BAD Sectors Emulation: No
Sub-Channel Data Fixed & Emulation: No
Laserlock Emulation: No
Current Language: English
############################ Device(s) List ############################
(FTDK CDRW4800B (0:1)
(GTDK DVDRW0404N (1:0)
(HAXV CD/DVD-ROM (2:0)
##################### Installed Device Drivers List #####################
ACPI.sys, afd.sys, ALiAGP.sys, alihdd.sys, aliide.sys, amdk7.sys,
aspi32.sys, atapi.sys, ATMFD.DLL, audstub.sys, Beep.SYS, BOOTVID.dll,
Cdfs.SYS, cdrom.sys, CLASSPNP.SYS, ctlfacem.sys, disk.sys, dmio.sys,
dmload.sys, drmk.sys, drvmcdb.sys, dump_alihdd.sys, dump_diskdump.sys, Dxapi.sys,
dxg.sys, dxgthk.sys, emu10k1m.sys, Fastfat.SYS, fdc.sys, Fips.SYS,
flpydisk.sys, Fs_Rec.SYS, ftdisk.sys, gameenum.sys, hal.dll, HIDCLASS.SYS,
HIDPARSE.SYS, hidusb.sys, i8042prt.sys, imapi.sys, iomdisk.sys, IOPORT.SYS,
IPFilter.sys, ipsec.sys, isapnp.sys, kbdclass.sys, kbdhid.sys, KDCOM.DLL,
kmixer.sys, ks.sys, KSecDD.sys, mbmiodrvr.sys, mnmdd.SYS, mouclass.sys,
mouhid.sys, MountMgr.sys, mqac.sys, mrxdav.sys, mrxsmb.sys, Msfs.SYS,
msgpc.sys, MSPCLOCK.sys, MSPQM.sys, Mup.sys, mxnic.sys, NAVENG.Sys,
NavEx15.Sys, NDIS.sys, ndistapi.sys, ndisuio.sys, ndiswan.sys, NDProxy.SYS,
netbios.sys, netbt.sys, NPDRIVER.SYS, Npfs.SYS, ntdll.dll, Ntfs.sys,
ntoskrnl.exe, Null.SYS, nv4_disp.dll, nv4_mini.sys, nvcap.sys, nvtunep.sys,
nvtvsnd.sys, NVxbar.sys, parport.sys, PartMgr.sys, ParVdm.SYS, pci.sys,
PCIIDEX.SYS, pfc.sys, PfModNT.sys, portcls.sys, PQNTDrv.SYS, psched.sys,
ptilink.sys, PxHelp20.sys, rasacd.sys, rasl2tp.sys, raspppoe.sys, raspptp.sys,
raspti.sys, rdbss.sys, RDPCDD.sys, rdpdr.sys, redbook.sys, RMCast.sys,
SaiMini.sys, SaiNtBus.sys, SaiNtHid.sys, SaiNtSub.sys, SAVRT.SYS, SAVRTPEL.SYS,
SCSIPORT.SYS, secdrv.sys, serenum.sys, serial.sys, sfmanm.sys, snxpcard.sys,
snxppal.sys, sojubus.sys, sojuscsi.sys, sr.sys, srv.sys, STREAM.SYS,
swenum.sys, SYMEVENT.SYS, SYMREDRV.SYS, SYMTDI.SYS, sysaudio.sys, tcpip.sys,
TDI.SYS, termdd.sys, TPkd.sys, update.sys, USBD.SYS, usbhub.sys,
usbohci.sys, USBPORT.SYS, vga.sys, VIDEOPRT.SYS, VolSnap.sys, wanarp.sys,
watchdog.sys, wdmaud.sys, win32k.sys, WMILIB.SYS
################## Detailed Information of Device(s) ##################
(FTDK CDRW4800B (0:1) detail information.
Vendor Identification: TDK
Product Identification: CDRW4800B
Production Revision Level: S7S8
Host/Target Number: 0/1
Support recording method: DAO, RAW DAO(96), TAO
BURN-Free Technology: SMART-BURN
Auto-Select best write speed: SMART-BURN
-* Note: This information below is provided by the unit, it might be inaccurate. *-
-* This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Response Data Format: 02h
CD-R Read/Write: Yes/Yes
CD-RW Read/Write: Yes/Yes
Read CD-R Fixed Packet: Yes
Test Write: Yes
DVD-ROM Read: No
DVD-R Read/Write: No/No
DVD-RAM Read/Write: No/No
Audio Play: Yes
Composite Audio and Video Data Stream: No
Digital output (IEC958) on port 1 Supported: Yes
Digital output (IEC958) on port 2 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: Yes
R-W De-interleaved and Corrected: No
C2 Pointers Support: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: Yes
Separate channel mute: Yes
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: Yes
Maximum Read Speed Supported (with current disc): 48X (7200 KB/Sec)
Maximum Write Speed Supported (with current Disc): 48X (7200 KB/Sec)
Current Read Speed Supported (with current Disc): 48X (7200 KB/Sec)
Current Write Speed Supported (with current Disc): 48X (7200 KB/Sec)
(GTDK DVDRW0404N (1:0) detail information.
Product Identification: DVDRW0404N
Production Revision Level: 1.05
Host/Target Number: 1/0
Support recording method: DAO, RAW SAO, RAW SAO+SUB, RAW DAO(96), TAO, DVD DAO
BURN-Free Technology: BURN-Proof
Auto-Select best write speed: Not Supported
Test Write: Yes
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/Yes
Audio Play: Yes
Digital output (IEC958) on port 1 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
R-W Supported: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
Maximum Read Speed Supported (with current disc): 40X (6000 KB/Sec)
Maximum Write Speed Supported (with current Disc): 16X (2400 KB/Sec)
Current Read Speed Supported (with current Disc): 40X (6000 KB/Sec)
Current Write Speed Supported (with current Disc): 8X (1200 KB/Sec)
###################### Source Disc/Image Information ######################
Type: Unknown
Path: D:\cdImage\
Session: 1
Track: 1
Session 01:
Track 01: DVD, Length: 2258994(4.31 GB), Address: 000000
####################### Dumping/Recording Progress Log #######################
13:41:00 Processor info: AMD Athlon(tm) XP (1333MHz)
13:41:00 Memory Available to Windows: 523,760 KB
13:41:00 Memory Buffer size: 128 MB
13:41:00 Image file loading: D:\cdImage\cd.img
13:41:00 DVD Source Info: Session: 1, Track: 1, Length: 4.31 GB / 501:59:69
13:41:06 (GTDK DVDRW0404N (1:0): Recording Method/Speed
13:41:06 Recording - DVD DAO - 1.0X (1380 KB/Sec)
13:41:06 (GTDK DVDRW0404N (1:0) - [Write ERROR] LBA: 0, Length: 16
S:KEY - 05/2C/00 - "Command Sequence Error"
13:41:06 (GTDK DVDRW0404N (1:0): Recording failed!
13:41:06 Error message: [05/2C/00] - Command Sequence Error
13:41:06 Image file loading aborted!
13:41:09 Something is wrong with the recording procedure!
Please check the log file and report any errors to Technical Support.
Results 1 to 1 of 1
Dl burning problems
By calanda in forum DVD RippingReplies: 13Last Post: 14th Apr 2010, 00:25 -
TYG02 burning problems.
By videobread in forum MediaReplies: 2Last Post: 11th Oct 2009, 13:51 -
DVD burning problems
By ssaamm in forum DVD & Blu-ray WritersReplies: 10Last Post: 22nd Sep 2007, 01:11 -
DL problems after successful burning
By m-man in forum Authoring (DVD)Replies: 7Last Post: 9th Jul 2007, 20:53 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 16:36
TDK CDRW4800B (0:1)
