i want to make an intro for my movie from some pics with music.
how can i do it? what program can do this?
thank's
Results 1 to 14 of 14
Even though there are lots of slideshow programs, I would give Video Studio 7 a shot with its music tracks transition, subtitles, etc. Trialware.
Hello. -
for some reason my computer can't run this program
could you recomend on other programs?
thank's -
Vegas Video
the recently SONY AQUIRED company
also has a cheaper version
SCREENBLAST
www.screenblast.com/ -
If you don't have those apps, and you want to save a few $100, Avisynth and VirtualDub are free.
After installing the latest Avisynth
Create a file pic.avs
Put the following in it:
Code:ImageReader("c:\myPic.jpg", 0, 1, 1, false) ChangeFPS(30,1001).Loop(5)
That should make your jpg into a 29.97 fps avi that plays for 5 seconds. You can also add music.
I just typed the script. I did not test it. You need to learn a little about avisynth to use it. (Same as the other apps).I mean it in the nicest way. -
Any video editor should do it easily. If you use NTSC, then save the pictures as 720x534 or 720x540, either one will work(Premiere recomends 720x534).
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Originally Posted by tl
Beginner Guide to Avisynth:- Install Avisynth (latest version)
- Install VirtualDub
- Make a text file on your desktop named "hello.avs" (no .txt at the end)
- put Code:
Subtitle(BlankClip(),"Hello")
- run virtualDub and open the hello.avs file using File/Open video file
- click on the Play button with the little I on it
You just created a 640x480 24fps 10 second movie.
Once you get the hang of it, it's quite powerful. I have access to Vegas/Permiere/etc. But I only really play at this stuff so I never bothered to learn and use them.
But then again, I live in a shack in the woods, kill my own food, and wear homespun cloths.I mean it in the nicest way. -
Originally Posted by ImaWeTodd
Vegas is as easy as it gets - you just drag and drop whatever files you want into the video and/or audio tracks...then render once you have it all arranged the way you want it.
The pics can be any size with Vegas - even tiny little animated gif files can be made into a movie.
I have Premiere 6.0 and the latest Pro version, but find myself using Vegas for most of my projects, 'cause of how user firendly it is and it gives me the best results.
You really don't have to be a tech to figure it out, but there are many online tutorials that walk you through the basics and show how to do some neat tricks. -
Originally Posted by tlWant my help? Ask here! (not via PM!)
thank's for all the help, i managed to do it eventually with vegas video, it really is a cool and easy program.
btw lordsmurf, at the adobe site it say that premier is only for xp. -
Only the newest Adobe Premiere Pro is for XP.
Comparing the two, Pro sucks. I'm sticking to 6.5, thanks.Want my help? Ask here! (not via PM!)
HOWTO: Edit Motion JPEG (MJPG) in Adobe or even Windows Movie Maker
By rallymax in forum EditingReplies: 53Last Post: 25th Jan 2012, 20:23 -
Let's Make A Movie Together!!!!
By budwzr in forum EditingReplies: 0Last Post: 4th Feb 2011, 21:40 -
Win Movie Maker jpeg quality
By The_Forastero in forum EditingReplies: 2Last Post: 19th May 2009, 12:35 -
Movie split on to 2 DVDs - make 1 movie.
By mattstan in forum EditingReplies: 3Last Post: 24th Oct 2008, 10:54 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 02:55
