The original avi is ok and virtualdub doesn't send me a vbr error message or something..
But after encoding with TMPGEnc the mpeg2 file is out of sync 1sec the whole time ?? I have tried multiplexing also but no help there..
Is there a way to fix this ?? with the mpeg2 file I mean ??![]()
Thanks but..
The avi i got is in perfect sync ,only after encoding the mpeg2 it's out of sync. Is there a tool where u could adjust that if the file is mpeg ?? -
The idea is to get the audio if the synch problem is constant, to add silence if it is too short, or cut it if it is too long. If the synch is gradual you use the Time Warp function in your favorite audio encoder. Mine is Gold Wave. What's yours?
Hello. -
If you're using TMPGEnc, you could also use the "Audio gap correct" feature, for some curious reason found in the "Source range" dialog ("Advanced" tab).
/Mats
fixing 'out of sync' audio in video file
By Nonamer in forum AudioReplies: 10Last Post: 19th Feb 2011, 02:03 -
Help! VirtualDub video/audio out of sync when enconding MPEG2 to XVID
By kbal in forum Video ConversionReplies: 6Last Post: 19th Dec 2007, 16:05 -
i'm trying to convert a mpeg2 file to an mp4-audio is out of sync!
By cduval04 in forum Video ConversionReplies: 1Last Post: 22nd Oct 2007, 17:56 -
How can I Add audio to a MPEG2 video file
By iantino in forum Video ConversionReplies: 1Last Post: 22nd Aug 2007, 15:46 -
How is done the sync between audio and video in a MPEG2-VOB file stream
By rmanal in forum EditingReplies: 0Last Post: 22nd Aug 2007, 10:33
