Hi there, just a quick question. Is it necessary to have dvd hadware in your system to re-encode mpeg files to dvd compliant mpeg's or svcd to dvd compliant mpeg's?
Trying to join mpeg files and re-encode using tmpge but whatever i throw at it it says that the file is unsupported.
I have a cd/rw sitting in the pc at the moment and a pioneer 106 waiting to go in the system.
Thanx for looking
Looking? You're kidding right?Thanx for looking
This question you will learn the answer to by heart if you spend a little time here. Anyway, click here.
Hello. -
Thanx for the info, but the reason i am asking is because i have all the relevent codec's installed and have done this a hundred times before. The merged mpeg files show as mpeg2 files but tmpge dvd author wont touch them. Ulead dvd Movie Factory 2 wont touch them. Tmpge Plus wont touch the files extracted from the bin file using vcdgear so i am a little lost.
Yes i clicked where you told me to , and i already had the vfapi settings changed.It has made no difference though.
Gonna shut down and put the 106 in see what that does. -
Once the 106 does not fix the problem, see if AviSynth will load the file into TMPGEnc for you. If not, see if Virtual Dub mod will load the video. If it does, frameserve it to TMPGEnc.
Hello.
DVD to MPEG Conversion
By Exodus119 in forum Video ConversionReplies: 2Last Post: 26th Feb 2010, 19:06 -
Fastest MPEG conversion?
By mingul in forum Video ConversionReplies: 2Last Post: 21st Nov 2007, 16:13 -
there's no sound with my mpeg-1 conversion
By darealest1 in forum MacReplies: 1Last Post: 13th Jul 2007, 08:12 -
mpeg-4 conversion help.
By ruk_design in forum Video ConversionReplies: 2Last Post: 28th May 2007, 03:18
