I have purchased Windvr3 to replace Windvr. When I press record, I get a message that tells me that the hardware does not support the record format. Does anyone have any suggestions as to what the correct settings would be to allow the use of this TV box with this software?
Everything works fine using the old Windvr software, except the inability to directly record to SVCD format, which has been my goal all along.
I just want to record TV shows, and then record them to SVCD with the least amount of work! Please help!![]()
Thanks.
Tom
tragatz@cox.net
tom_ragatz@rac.ray.com
AnonymousGuest
Hi,
Does WinDVR3 feature :
a) The ability to record audio at 48 KHz ?
b) Does it include a counter of captured X dropped frames ?
Thanks ! -
Yes to your query about 48.0. I do not know the answer to your second question.
AnonymousGuestThanks, this sw would be really great if it featured this function - version 1.5 doesn't;Originally Posted by tragatz
Your hardware does not support the minumum capture setting selected in WIN DVR3.
AnonymousGuestThanks, but could you please be more specific ?Originally Posted by jdizzy40
What is the weak point in my system ?
Thanks -
I have found that I can record using Windvr2, and then use Windvr3 to burn the CD using the transcode feature. I now find the result has great sound but is monsterously pixilated as far as the video. Am I doing something wrong, or am I expecting something that cannot be done?
I simply want to capture video and audio with the kworld usbbox, and then transfer it to watch on my 25 inch TV in a reasonable resoluton.
Please advise.
Thanks.
tragatz
Tom Ragatz
tragatz@cox.net
Sound wont work on KWORLD DVD Maker USB 2.0
By BiggerJim in forum Capturing and VCRReplies: 1Last Post: 24th Nov 2014, 07:06 -
Inquiry - Kworld SA-290-Q LE TV Tuner Box
By Frank-0-Video in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2009, 14:39 -
Problem with kworld dvd maker 2800D usb - Compression artefacts?
By jhowee in forum Capturing and VCRReplies: 5Last Post: 10th Feb 2008, 06:48 -
How to use Kworld DVDMaker USB 2.0
By barryblizzard in forum Newbie / General discussionsReplies: 0Last Post: 25th Jan 2008, 10:21 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 10:59
