I have some DVD's that I'd like to edit the music themes. how do I extract just the audio track from the DVD?
What programs would I need?
I have:
Goldwave
TMPenc
DVD Decrypter
DVD Shrink
G Spot
DVD2SVCD
Virtual Dub
I thought prior to this that I had grabbed the audio track using VDub, but now I can't remember how I did it... if I did it at all with that one!
Thanks to all who take the time to reply!
J T
Results 1 to 11 of 11
If you want the entire DVD or chapters use DVDDecrypter ,IFO Mode and select Stream Processing->Demux.
Then use AC3Tool to convert to WAV/MP3.
You can then use Audacity to add silence or whatever. -
rip the dvd with smart ripper, then use vob2audio http://www.digital-digest.com/dvd/downloads/vob2audio.html to extract the audio from the vob files. then use cool edit or any other program to split the file into separate tracks. i have used this method and it works great.
MovieGeek said:Then use AC3Tool to convert to WAV/MP3.
J T replies:
AC3 TOOL looked at the files I got from DVD Decrypter and put up a fuss that there was some sort of ERROR and then it closed!
Now what do I do?
thanks!
J T -
I use VIDOMI to make a PCM-AUDIO 44KHZ bearing AVI from the VOB
then I load the resultant AVI
(one big file the MOVIE's Length that's completely unplayably large in weight cause of the PCM audio but serves as my 'internegative' )
I load this AVI into PREMIERE and export timeline as WAV
or import to TMPGenc and render a WAV file
thus VIDOMI (free) has dealt with the AC3 to WAV conversion--
but kept the VIDEO so now you have to seperate out the VIDEO..lots of programs do this...but you must use VIDOMI on decryptedVOB's on the HARD DRIVE -
My approach is to:
1) Rip the dvd to hd, rip in chapter mode if music DVD.
2) Load the VOB(s) you want the audio from in DVD2AVI. Make sure "Decode" is selected under Audio -> Dolby Digital, then select "Save Project". This will leave you with the audio in wav format.
/Mats -
"AC3 TOOL looked at the files I got from DVD Decrypter and put up a fuss that there was some sort of ERROR and then it closed! "
Make sure the extension is .AC3 instead of .VOB
BTW...AC3Tool doesn't support DTS. -
AC3 TOOL wont work
any other ideas?
i have a few music dvds, and i was looking to save the audio to a wav(or mp3)
but i dont want just record song by song with a recorder program
or to encode the whole audio file in one big file and then cut song by song
anyone know how to do it automatically?
thanks
-StKIncrease knowledge, increase sorrow. -
stk - why not put a little effort into it, and follow one of the many suggestions presented earlier in this thread? They do work.
/Mats -
#1 DVD Audio Ripper is what you need.it can rip dvd audios to mp3,wav,ogg,wma.support to edit start time and end time.
http://www.apollo-tech.com/dvd_audio_ripper.exe
Audio track shorter than video track in MPEG Video Wizard DVD?
By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 14:24 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 13:16 -
need to substitute spanish audio track with english track
By rebeltaz in forum AudioReplies: 5Last Post: 26th Dec 2007, 20:12 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 09:25
