I’m using TMPEGEnc PLUS 2.5 (Version 2.510.49.157) to convert AVI’s into DVD / VCD, however I have started to get a lot of ‘Floating decimal point overflow’ errors, is this to do with a corrupt input file (if so how do I correct this? I have tried reconverting the files in VirtualDubMod) or is it some settings I have wrong within TMPEG?
The error does not always appear at the same place so I’m assuming it’s a settings issue rather than a corrupt file.
Any suggestions would be appreciated.
Cheers
TMPEGenc h.264 conversion error
By iGnight in forum Software PlayingReplies: 2Last Post: 16th Jan 2011, 11:14 -
TMPEGEnc DVD Author Ordinal Error
By justin81 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2009, 21:33 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 09:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 03:22 -
TMPEGENC keeps closing itself because of an error
By Akhet in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2007, 01:38
