I have burned movies to cdr and need to convert to dvd to play
on dvd player. is there a way? thank you.
There's several ways, try here.
All of the methods involve stripping the mpeg from the disk, making them DVD compatible (some more compatible than others), then authoring and burning. How compatible you make your file is up to you, but you have several choices. (S)VCD has 44.1 KHz audio and should be resampled to 48 KHz to be DVD spec. SVCD video resolution is not DVD spec but it will still work an many DVD players (esp. if they play SVCD already) and some authoring programs will accept it and some won't. To be completely DVD compatible your SVCD video needs to be re-encoded, your choice. VCD video is DVD spec. SVCD2DVD is a commonly used method.
Good luck!"Art is making something out of nothing and selling it." - Frank Zappa
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 17:31 -
.cdr on a DVD+ needs to be converted
By jamesmarcustucker in forum Video ConversionReplies: 20Last Post: 8th Sep 2007, 16:40 -
.cdr file on a DVD+
By jamesmarcustucker in forum Video ConversionReplies: 1Last Post: 6th Sep 2007, 08:13 -
CDR TO DVD software please
By Lennoxtown in forum Authoring (VCD/SVCD)Replies: 5Last Post: 7th Aug 2007, 13:04 -
DVD Media... NO CDR!
By Lighters in forum MediaReplies: 5Last Post: 5th Jun 2007, 12:26
