I have weired problem. I am using studio 8.10 and have created several dvd for my home video.
I have issue with one of them. When I complete editing it shows me about 13 GB of free space against 8.2 GB needed to create disk. It starting rendering and then after 5 hrs (aftere completing rendering) give me error that there is not enough room on D: Free up some space and try again? Now there is about 5.6 GB free space left. Is there any work around for this?
Does any one have seen this error? Any help appreciated-B
Try running scandisk on your drive
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
Tried with Scandisk and same thing. I think Pinnacle Studio has a bug and not calculating space properly. It does not make any sense as when I start making movie, it say I have more then double space and after randering it complaints about space.-B
I'm using version 8.8, but I think the 8.2 GB it says it needs to create a disk is actually about 4 GB short of what it actually needs. The 8.2 is used to create the files used to create the disk, then it needs another 4 GB or so to actually create the disk. It may be off in calculating free disk space, so if it needs 4 GB and you have 5.6 free it may not think there's enough space.
While a defrag or scandisk might help, I think your best solution is to clear up some more space on the drive. -
BOBK,
You were right. I was able to create disk last night by using other disk where I had about 15 GB space free. I think Studio miscalculating disk space or need some temp space to create final files.-B
avstodvd disk space
By nhn21 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2010, 15:16 -
not enough disk space - Adobe premier Pro 2.0
By Reggie6966 in forum Newbie / General discussionsReplies: 11Last Post: 8th Nov 2009, 03:07 -
Why am I losing so much disk space?
By Han Solo1 in forum ComputerReplies: 7Last Post: 24th Nov 2008, 20:17 -
Super eats all my disk space
By ZenSojourner in forum Video ConversionReplies: 10Last Post: 21st Oct 2007, 02:27 -
Hard Disk Space When Encoding
By Em in forum Newbie / General discussionsReplies: 8Last Post: 21st May 2007, 12:35
