Hi,
I have 3 faults, has anyone else experienced these following problems?
1) Situation: Trying to Timer record 2 or more different programs onto DVD+RW.
Problem: When I timer record the second program it overwrites the 1st program, I am left with only 4, or so, minutes at the start of the 1st program.
Checks done: I've made sure the lengths of the programs were ok for the disc. I’ve checked the record mode. Also the timer settings are correct.
2) Situation: DVD-R recorded from PC.
Problem: Will not play, either comes up with 'Empty Disc' or 'Disc Error'.
Checks: Made sure the Disc was the correct 'region'. Played on a cheap player with no trouble at all.
3) Situation: Recording a DVD+RW to play on another machine.
Problem: Picture on playback, on the other machine, freezes badly! But after a second play on my DVD recorder will also freeze, but not so badly. Freezing gets worse the longer the DVD player is on.
Checks: The other DVD player is a Marantz (Part of Philips) Tried different discs and seems to have alleviated the problem. But the discs that were giving the problems were Philips discs. I am using Memorex discs, but how many recordings can I make on these discs before they go bad? I had only made 2 or 3 generations of recordings on the Philips DVD+RW discs before they gave up the ghost.
I've sent e-mails to Philips, and replied to their product survey response e-mails (Not very good, with regard their DVD recorders)
Thanks for any help you can give me.
Results 1 to 1 of 1
philips dvdr880 issues...
By colcol1 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 18th Jan 2012, 10:00 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Help with PC to HDTV Needed
By denzlite in forum DVB / IPTVReplies: 12Last Post: 13th Jan 2009, 16:34 -
Compressor Needed
By mytabbycat in forum MacReplies: 4Last Post: 3rd Nov 2007, 05:54 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
