Hello,
I am using Dazzle Moviestar5 and the Dazzle DVC-80 to capture some video off some VHS tapes. I then take that video and use Dazzle DVD Complete to author the DVD. Everything is cool except I notice a small amount of jerkiness on pans and other places (such as a spinning globe). Is there anything I can do to get rid of this?
Thanks,
* Robinson
Do a search on Jerkiness.
Chances are, when you've encoded your product, the field order got reveresed..
The best product i've used for this is Restream. Unfortunately, you're required to use strictly your .m2v stream..So if you've already captured in mpeg, then you'll need to split the audio and video, and feed the video into Restream, to change the flags...
Good luck!!
Is there a jerkiness (motion detection?) setting in CCE?
By robrosen in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 17:42 -
Bad NTSC to PAL converstion - jerkiness. How to fix?
By PTRACER in forum Video ConversionReplies: 34Last Post: 11th Sep 2007, 18:00
