i have 2 svcd images in bin formate missing theyre cue files ive tried burning with alcohol 120% but the resulting svcd will not play on my standalone dvd, which i never have a prob with, The disc will wotk on my pc, I have tried mounting the bin files and making a new image but that led to more coasters!!! lol, ne help or suggestions?
What authoring program did you use that only created the bins, without the ques? I know you didnt download a movie illegally and are asking us how to help you finish with your piracy, so let us know what steps you took in creating it and we can help you out.
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
You can write your own .cue for the bin files using notepad,below is how it needs to be writen for an svcd simply change the first line of the example to match the directory/location and filename of the bin files then save it in the same directory using the same filename as the bin files eg: "filename.cue" , select all files in the save as type dropdown.
you will now have a cue file for the bins and you can burn them with cdrwin or nero.
here is what your cue file should look like in notepad (this is a standard (s)vcd cue file
missing converted files
By chucksupple in forum ffmpegX general discussionReplies: 2Last Post: 2nd Apr 2012, 15:25 -
VOB Files Missing or Not?
By Spetznaz24 in forum Newbie / General discussionsReplies: 10Last Post: 14th Apr 2008, 17:36 -
vob files now missing
By flyingrrt in forum DVD RippingReplies: 2Last Post: 20th Dec 2007, 12:35 -
missing ifo-files
By scio_fantasio in forum MacReplies: 5Last Post: 12th Dec 2007, 23:04 -
Missing files
By justinguitar in forum ffmpegX general discussionReplies: 5Last Post: 25th May 2007, 18:40
