HI,
I apologise if this has been asked before and if there is a faq on this then please just point me to it, but it is not really about converting PAL & NTSC.
I have a NTSC camcorder, bought in the USA as it was miles cheaper and fine for what I normally will do, which is underwater recording on US equipment and burning DVDs.
I also wish to be able to burn DVDs for friends with the Camcorders which would be PAL.
I know that I can only change from PAL/NTSC about 5 times. Is there anything that will allow me to set my Pioneer A05 DVD writer to be able to swap modes as and when I want?
TIA
NTSC/PAL has NOTHING to do with the max 5 changes. The 5 changes are for dvd regions on commercial dvds. Homemade movies are usually region free so it should not be a problem.
But you can anyway make your dvd-rom region free:
https://www.videohelp.com/tools#Regionfreetools
and dvd player
https://www.videohelp.com/dvdhacks -
I only have region 1 DVDs and yet when testing my burns in my DVD reader it has gone on to region 2(I thought because I had burned as NTSC for my US friends)
I will check out the tools.
Thank you.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
