  1. Hi
    Small problem
    Friends in usa sending dvd vids of family - but in nstc
    how do i convert to pal
    tried splitting to avs/m2v but wher did ac3 audio file go to
    used dvd2avi
    avisynth
    tmgenc
    any ideas of a simlper way - this one didnt't work out for me
  2. Member SanderMan's Avatar
    Feb 2001
    Netherlands
    You can do this with dvd2svcd (now also dvd2dvd). Just tick the ntsc to pal box and it will do everything for you.
    Good luck!
    May 2003
    Pal Realm
    Are you sure you even need to convert? Most UK players/TVs play both fine. :c)
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
  4. Hi
    Thanx for quick response
    Yeh I need to convert
    Also bought a dvd when i as on holiday
    tring to get it to pal
    hav dvd2svcd will give it a try
  5. Hi Guyz
    Just tried Sefys guide to dvd rip/copy/author
    the resulting dvd has the lip sync out a cuople of
    seconds
    Anyone advise where i may be going wrong
    Using dvd2svcd(dvd)
    Tmpegenc
    Tmpegenc author
    copying nstc dvd to pal dvd
    in anticipation of a quick reply
    many thanx in advance
    kriffendorf@aol.com
  6. I Don't think you need to do any conversion to PAL as most if not all of the DVD Players in PAL regions do a NTSC to PAL playback.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  7. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Here's the simple solution to your problem.
    Take your NTSC DVD and put it into your PAL DVD player.
    Press play.
    The End
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
