Guys having alsorts of problems here.
Im on PAL and am just trying to extract the audio do i can convert to an mpeg so do the usual stuff with virtual dub. the file sits there(WAV) but when i try and complete the process with tempeng just get the video no audio. im not trying to convert from NTSC to pal cos its already done. i have just reinstalled the divx package, so not sure if that has helped. anyother ideas please?
8) please explain all your steps in DETAIL in english. Read it back to yourself to make sure it makes sense. Then post it. and search the fora for answers.
fora plural of furum.
And dont be so phallo-centric .. women use these forums too.Corned beef is now made to a higher standard than at any time in history.
The plural "guys" seems to be approaching unisexuality these days. Know plenty of females that use it to refer to others, mixed groups, men that do it also....
As for the original question I'm afraid I have to hand in my
notice as well
-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more! -
So if fora is the plural of forum
why use the word forums at the bottom of your post?
Guys was a bespoke word, most people do seem to use it in a unisex way nowadays.
ill be back later to post in more sense as Rabies advised -
Ok heres what i do using virtualdub
1 File>Open Video
2 Get message 'Virtualdub has detected an improper VBR stream' i click OK
3 Select File information
4 IS 2 channel Fraunhffer audio
5 Audio->Full processing mode
6 Select Conversion
7 Set Sampling rate to 44100Hz.
8 File->Save WAV
all seems fine everything looks ok Wav is correct size, ie massive.
9 Open TMPGEnc
10 In project wizard click on VCD, PAL
11 Select source file and Wav File.
12 change source range as is too big for one VCD
13 Leave bitrates as they are
14 Click encode.
15 Check File, video is fine, but no audio there.
Is there something im doing wrong?????
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 13:38 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 16:26 -
Adding audio (wav) to video (avi) (want to delay start of audio)
By Lanton in forum Newbie / General discussionsReplies: 2Last Post: 12th Apr 2010, 13:50 -
Are Wav audio and PCM audio the same thing?
By yoda313 in forum AudioReplies: 2Last Post: 22nd Mar 2009, 16:46 -
Converting .FLV audio to .WAV
By socool135 in forum AudioReplies: 1Last Post: 20th Feb 2008, 20:24
