  1. I have been trying to encode an avi file to mpeg dvd PAL standard. Have been using goldwave to extract/convert the .wav file and started to encode with TMPEGnc 2.5 choosing the wizard and some small tweeks to get the file size right. Everything fine until i check the result about half way through the file audio looses sync have tried this on several films still the same result. Can anyone point me in the right direction please
    Tools used TMPEGnc 2.5, GoldwavePro, TMPEGnc Author.
    Apr 2002
    The State of Frustration
    When you have any project that uses an AVI file, always check it for bad frames. We shoild not go any further until you so. Get back to us. Click here.
    Hello.
  3. Have looked at vdubmp3 everything followed and sorted then loaded file to vdub got this msg will have to get my head into more of the guides and sort out the wave file. Will get back to you when i have made more progress.
    Tks for now
