I have 650 mg of continuous(mixed) sound (.wav) and about 2.300 photos (.jpg). I would like to make a ONLY ONE file (.mpg) to play my photo album.
IMPORTANT: I need a 5 seconds delay for play each photo with continuous sound.
Is it posible with Nero and TMPGenc?
Tks for any help.
I'm not sure how to do this with TMPGEnc, but I know w/ premier (you can download a demo from adobe's website, check out the tools section of this site) you can create one large file by importing the audio, then the pictures, and setting the duration for each picture on the time line to 5 sec, and putting them one after the other, will create one large movie file like you want. then you can export it as an mpg.
hope that helps.
-rage -
You need another piece of software.
I use StudioDV (a video editor software).
1) import all the JPG as video clips (each has a default of 4 second long for Studio DV)
2) add audio (.wav) to the sound track
3) output the video to an AVI file
4) use TMPGEnc to encode the AVI file to an VCD or SVCD MPEG file. I recommend SVCD for better picture quality
5) burn the MPEG file as S/VCD
a few gotchas:
1)the number of photos really depends on the bitrate you use to encode to MPEG-2. With 2300 photos at 4 second each, this is about 2.55 hours of video !!!
2) who really want to watch 2.5 hours of slide shows !!!
To go around the issue #2, I always split into mutiple albums, each is an AVI file (and therefore an MPEG-2 file). This way, I can index into the album I want to watch.
JPG to AVI Back to JPG is it possible?
By concisa in forum Video ConversionReplies: 3Last Post: 11th Apr 2009, 09:06 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 19:40 -
NO sound when i try to burn in nero 7..
By lil_jayz76 in forum AudioReplies: 3Last Post: 3rd Nov 2007, 20:05 -
Extracting jpg photos from the ITEM####.dat files in the VCD segment folder
By H-Man1953 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 06:54
