  1. I've been creating my VCDs using similar sets of custom preferences: is there a way to save my custom preferences as a Quick Preset?
    Thanks -
    Steve
  2. You can use "Save preset" from the File menu, and load the preset by double-clicking its icon.
  3. It might be a little more obvious to some users if the save/load preset selections were also mirrored in the "Quick Presets" pull down menu, as that is where you usually see such an option in other mac apps.
    Listen not to the Devil, for he mixes lies with the truth... and vermooth.
