Newbie here. I riped a disk to hard drive with DVD Decrypter, now I want to burn it to disk, how do I do it? I selected the file from hard drive on "please select a file" but it doesn't open. I'm real new and real dumb, please help me.
Thanks,
Brian.
Did you rip as an ISO or files? If files, did you rip all the files. What file did you try to select? Are you trying to burn the disk with Decrypter (if yes then you should have ripped as an ISO).
(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
Thanks Bob, I must have selected the wrong file type. ISO worked. If you would be so kind as to help me with another question it would be much appreciated. I successfully ripped and burned a DVD-5 with DVD Decrypter. When I attempted a DVD-9 I ripped it to hard drive successfully, but failed in the burn. I didn't see any means to create a split point with Decrypter. So I started the burn hoping all would work out, but of course it didn't. How do I create the split point for the second disk? Should I burn with this software, or another. Thanks again.
use dvd shrink to rip the files and reauthor to 2 disks or compress to one disk burn with nero or record now max or similar
DVD Decrypter 3.5.4
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 9th Mar 2010, 15:48 -
dvd decrypter
By dr strange in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2009, 15:11 -
DVD Decrypter
By Beaker14 in forum Newbie / General discussionsReplies: 17Last Post: 26th Oct 2007, 23:39 -
I am using DVD Decrypter
By Lissettep in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Oct 2007, 17:55 -
Help with DVD Decrypter
By Me-Hostage in forum DVD RippingReplies: 10Last Post: 20th Aug 2007, 09:12
