    Oct 2003
    Texas
    How does this program decides what mpeg1 or mpeg2 codec to use?
    For example I installed a program to edit videos: videowave, and when I read the properties the mpeg videos, it says MGI MPEG-2 Video Decoder.
    What happens if I backup those moveis and later I want to read them, do I need to have that codec available?, or it's whatever is available?
    Apr 2002
    The State of Frustration
    Usually, it uses the Direst Show command to decode videos. Your players also have codecs that can run your MPEG videos as well.
    Hello.
    Oct 2003
    Texas
    I did uninstall the program and it used another codec, from the powerDVD player, so we should be fine here.
